Tire Losing Air?
Agree on the temperature changes - it does make a big difference. The soapy water spray works great - that is what many use when finding a gas leak around a gas meter (after using the sniffer). Works just as well for an air leak in a tire.
There is a seal at the TPMS to rim junction on my other car. Maybe the hold down nut neets tightening.
Probably this. Don't overtighten the holddown nut on the valve, though. You will deform the O ring and it can leak worse.
Received 3,366 Likes
Yeah, cold here for FL! Only 1 tire was low so it cannot be the cold. I just checked the tires again and both rears were stll at 40psi so I am baffled. I cannot see this resolving itself since both the car and my gauge showed a decrease. So I rolled the car a bit so the tire is in a different position and I will check it again tomorrow with my gauge and while driving. Stay tuned.
Hope you find the gremlin. But it still could be temps. Up in Philly when the weather shifts I lose air very inconsistently in the 4 tires, location in garage, proximity to the door, etc... Good luck with the search.
Cold temps will result in pressure drop in all 4 tires, not just one. I wouldn’t wait any longer, it’s obvious there’s a small leak, more than likely from a nail or screw, extremely hard to find with tire on vehicle. Keep us posted.
I lost 4 lbs in my right rear yesterday just sitting in the office parking lot. Filled it at home and lost 2 last night.
sitting in the lobby at Suncoast as I type...
arghhhhh
arghhhhh
The most common tire to pick up a nail and fail is the rear passenger side one (closest to the curb around corners). Several years ago, I made the mistake of only topping up my rear tire a couple times and then came out to the car after a meeting to find a flat. Bob, it’s odd that only one tire lost pressure initially and now is holding air ...
Received 5,389 Likes
Here's a trick. Use your cell phone camera. Snap a few pictures of the tire, and blow them up to look/see. It helps you to see the far inner edge. You may have had a nail/screw for a l o n g time, and wore the head off of it.
I just checked it again and it is still at 40, right where I left it and that is after rotating it a few times. I live in a condo and do not have the tools to take of off but I do have soapy water, which is great since I do not like to get my hands dirty. We are going out to dinner later and I will see what the car says and report back. Could it be that since it is cold (upper 40s) and the concrete is even colder in the garage a hole could have closed up, and when I drive the tire heats up and it expands allowing air to escape?
Speaking of tire gauges, what is the best? IXLR8 mentioned a Longacre and Suncoast has them for $28. I have gone through several the last few years since they work at first but start flaking out thereafter.
^can't beat Longacre. Quality product.
Bob I had a similar issue which ended up getting worse as the weeks went on. Had to use the tire inflator kit a few times when the car sat for 4+ days.
Tire shop found 2 nails in the tire which I was never able to see.
Found a big open area and obliterated the rears and then I replaced all four keeping the fronts aside as spares.
