Ideal OEM Tire Pressures for 991.2 Targa 4GTS
Wondering what the thought is regarding ideal tire pressures for OEM P Zero's on a new 991.2 Targa 4 GTS
Sticker on the door states Cold Temp should be Front 33 Rear 45.
Received 5,388 Likes
Comfort levels.
Fronts 32/34
Rears 35/36
Fronts 32/34
Rears 35/36
Originally Posted by bosco42
Wow...big difference on the rears.
While it is sitting in the garage for the winter should I over inflate them to prevent dead spots and, if so, to what pressure ?
Yes. I go about 58 for winter hibernation.
Received 3,365 Likes
I suggest you play around with them and see how they feel at different settings; however, no more than 40 anywhere (other than storage). I am running 33/38 cold on my Targa GTS.
Any idea what those figures increase to after cruising (not racing) for about 30-60 minutes on a 36 degree winter day and an 80 degree summer day ?
On a warm day, tire temps increase about 4-6 lbs from my experience
On an 80 degree day, I'd expect the fronts to pick up about 2 psi and the rears to pick up about 3 psi.
Yesterday was a sunny 36 degree day with clear roads so I went for a drive to familiarize myself with my new Targa.
When I returned home I noticed the TPMS registered 35/45 which means that it was most likely around 33/43 when I started ??
The point is I did not find the ride too firm at all ( actually quite comfortable ) so I suspect if I adjust it to the cold pressures being suggested it will feel down right soft and cushy.
Thoughts ?
Thoughts ?
Be careful driving in 36 degree weather with the factory OE summer tires.
LOL, I consider anything over 75 degrees hot.
