Losing Oil at Drain Plug
I own a 2017 Carrera and have been doing my own oil changes now and have noticed a very small of oil after the car is parked. After researching I ordered these oil drain plugs off of amazon.
Any thoughts to why oil would be coming from these plugs?
Turns out after reading some of the newer reviews for these plugs , They Leak... I went to partsgeek.com and ordered these if anyone is interested.. Febi Oil Drain Plug- 139915-08059803
I’m of the opinion that the plug doesn’t need to be replaced with every change. The o-ring inspected at every change and the plug replaced every 4-5 changes. I understand replacing crush washers every time, but there’s very little torque on the o-ring.
I oil drain I ordered is made by Bilstein not some cheap parts from china...
I'm scratching my head on this one: The OEM plug is less than $7.
Part number 958.103.801.00. https://www.gaudinporscheparts.com/o...ug-95810380100
Why try to outthink the Porsche engineers' recommendations for $7?!
No one is trying to outthink Porsche but rather find a simple oil drain plug since it seems to be a simple part. Trying to make yourself sound so intelligent saying such a thing is very arrogant and uncalled for. Thank you for the oem part number and I did go ahead and order from your link.
Good day sir
Good day sir
Good day sir
Good day sir
I'm glad you found the link helpful. I hope it resolves the leak for you.
