991.2 GTS with GT3 Wheels
haha, 4mm narrower is hardly sunken. but I agree that widening would be better.
Yes, the front wheels are .15 inch “sunken” in. I compared the GTS stock and GT3 and it’s not noticeable. If you can notice .15 inch, you have a better eye than me. The stock GTS wheels on the front already look like they could use a little less offset though. That said, I consulted Elephant Racing and was planning to go with adjustable LCAs ($1200) but they recommended going with their Eccentric solid bushings instead as they were a cheaper solution ($390) and to adjust the factory Eccentric camber plates at the top of the strut, and boom, picked up a .5 inch increase in front track, more than negating the offset penalty going from GTS to GT3 wheels. And I went from MPS4S to MPSC2.
https://imgur.com/gallery/y7HjPeG
Yes, those are the GT3 wheel offsets but I wouldn’t recommend going with a 315 rear tire as it will poke. A 305 is the max width I’d recommend on a GTS. For rear tires, probably best to go with a 295 rear tire.
Trapperj (09-07-2020)
Basic Sponsor
The widths of the GT3RS wheels isn't the problem it is the offsets that are the problem. We can and have fitted 991 GTS' with 9.5" fronts and 12.5" rears however it was with offsets that pushed the wheels outward more which allowed for the inner clearance to be perfect. Since the GT3RS wheels have weaker offsets (wheels tucked in more) the inners will rub.
Wheels Boutique // 786 249 0127 // Sales@wheelsboutique.com
Follow us on YouTube: www.youtube.com/user/WheelsBoutique
Largest Dealer In The World for HRE Wheels, ANRKY Wheels, Vorsteiner Wheels & Aero, Akrapovic Exhaust, & iPE Exhaust
BBS, Forgeline, & TechArt Premium Dealer
Brembo / Rotiform / KW / H&R / Novitec / Brabus / Mansory and tons more...
