Upgrading .2 steering wheel to one with heat and MFC
Have a PDK .2 steering wheel with the mode switch.
After many hours of research, i can't find anything relative to my question.
Which is to convert a .2 steering wheel to one with heat and MFC.
Any help or insight is appreciated.
I think heat is more complicated as you need a physical switch behind the steering wheel to turn it on/off. So you most likely need a new steering wheel if you need heat.
Negative on Suncoast. I purchased a heated MFC .2 wheel. Another member was nice enough to share what he did to get it to work. Which ends up being at the dealer anyway.
I will have the dealer do the necessary programming and install.
Will report back on cost and parts needed.
SJW, a Carin' kinda guy
