PDCC Service & Belt Replacement
Old 12-13-2018, 08:20 AM
Tampa991
Tampa991's Avatar
It will depend on what your warranty contract states. You are likely not obligated to get the work done at the dealer.
Old 12-13-2018, 08:54 AM
Bud Taylor
Bud Taylor's Avatar
Default part number /failure
Did you get the PDCC bottle part number ? Could they be replacing these due to the high number of PDCC failures or could the failure be caused by people not replacing these ? Why would you not replace the bottle again ?
Originally Posted by CSK 911 C4S
That's a bit out of line.
I was charged $1034 after some discount for Belt replacement, PDCC bottle replacement, AWD Clutch fluid service, Brake fluid flush.
BTW I'll never replace (or have it replaced) the PDCC bottle again unless it starts leaking.
Old 12-13-2018, 09:01 AM
Tampa991
Tampa991's Avatar
They are not replacing them due to a campaign, it is a service interval that was established when the car was new. Trying to find the part online....
Old 12-13-2018, 09:21 AM
CSK 911 C4S
CSK 911 C4S's Avatar
The bottle on our 991 is burred behind the pump and if the tech can mess it up requiring a week delay to get a new tube from the mother land I'm just going to push it off until something happens.
I noticed our bottle is made from a different plastic than the other Porsche models so I'm hoping it's a stouter plastic made to take the heat.
I'll post up the PDCC part number when I get my car back from service..... the slip is in the glove box.
Old 12-13-2018, 09:26 AM
Tampa991
Tampa991's Avatar
Thank you - please do..I can't find it!
Old 02-05-2019, 11:45 AM
Bud Taylor
Bud Taylor's Avatar
Default following
Did you get this done ?
Old 02-05-2019, 11:54 AM
Tampa991
Tampa991's Avatar
No, not yet...one of my indy's suggested just flushing the system with new fluid.
Old 02-05-2019, 04:00 PM
Tampa991
Tampa991's Avatar
I changed the oil this afternoon...and swapped out some old PDCC fluid with new stuff...it wasn't the worst color.
Old 02-05-2019, 04:35 PM
CSK 911 C4S
Did you just suck it out of the bottle?
Old 02-05-2019, 04:37 PM
Tampa991
Tampa991's Avatar
Yes...drove it around for a bit to get the pump moving things around, the fluid still showed the same color.
Old 06-02-2020, 02:02 AM
BradB
BradB's Avatar
Sorry to dredge up this old thread, but exactly what fluid is in the PDCC system? And did you get it at the dealer or source aftermarket? Thanks!
Old 06-02-2020, 08:40 AM
Tampa991
Tampa991's Avatar
Power steering fluid. Pentosin CHF 11S, you can get it almost anywhere. The PDCC pump is a hydraulic power steering pump
Old 06-02-2020, 02:28 PM
BradB
BradB's Avatar
Thanks!
Old 08-10-2022, 03:51 AM
driven991.1
driven991.1's Avatar
How has the car been since its been 3 years with the pdcc fluid change only? I am debating the same.
Old 08-10-2022, 09:15 PM
CSK 911 C4S
I just had this done at my dealer so here are all the part numbers. I'm a DIY'er but I don't want to screw up this system.
Slip below:
Quick Reply: PDCC Service & Belt Replacement
