Battery replacement quote - does this make sense?
#76
Found the answer to the "braking energy recuperation" theory in the Banner website FAQ. Now it is just a matter of confirming that the 991 alternator acts as described below.
Quite simply, brake energy recovery.
When you accelerate or brake, some of your car's kinetic energy is usually lost. Part of this energy is recovered through recuperation.
This is because the alternator (also called generator) intentionally puts more strain on it in this phase, the voltage of the alternator is raised so that the charging process is accelerated and thus more energy is supplied to the battery. The alternator converts the kinetic energy into electricity, in principle like a bicycle dynamo. In acceleration phases and in normal operation, the output of the alternator can be partially reduced or even set to zero, which means more energy is available for the drive.
The reason: The vehicle now uses the energy that the battery has previously stored. This saves fuel and emissions. Because Banner Running Bull series start-stop car batteries are real CO2 and fuel savers.
#77
I do not know what an Enhanced Flooded Battery (a Banner battery term?) is, maybe just a fancy name for a different FLA (Flooded Lead Acid) battery that can take cycling.
#78
I don't think so. What was your source? As far as I know from my years working in a battery lab, an AGM and GEL is.
What battery lab did you work in all those years?
Here's for the EFB description.
The enhanced flooded battery (EFB) is an upgraded conventional battery. Special additives and the use of a polyester scrim lend the active mass additional hold. As a result, the battery has improved cyclical resistance and is extremely vibration resistant.
Banner recommendation. For safety reasons, when installing the battery indoors always use a degassing hose, which in an emergency will conduct the gas outwards.
TECHNICAL DATA AND INFOS
- Nonwoven layer on the separator and a special active mass recipe
- Twice the cycle life as compared to standard starter batteries.
- E3 classification pursuant to EN 50342-1.
- Highest V3 vibration resistance pursuant to EN 50342-1
- Double-lid top for maximum leak protection and the highest operational safety
- Absolute maintenance-free owing to modern calcium mesh technology.
Cheers,
#79
This is the Banner battery I believe we have in our cars, less the Porsche and Porsche part numbers on the label. The specs are the same as those in my car. Some vehicles have the 70 Ah battery, I have the 80 Ah battery.
#80
Bammer Batteries Source US
Where did you find in the Us to purchase banner batteries (I can only find them in Europe).
National Defense battery lab where I tested chargers and batteries. We would do the full test on batteries: load and capacity test using proper but time consuming equipment. Its why I have seen big differences in readings between fast and easy conductance testers like a MidTronics or that Solar shown a few posts above to real "time consuming" capacity tests using a Programma Torkel 840/860. As for charger testing, lets not go there other than to say many so-called high tech chargers promise you the world...right on their packaging. lol
#81
All this talk about AGM, VRLA, SLA, EFB is making my head spin. Can't we just buy an Interstate or Duracell AGM battery to replace the Banner when it dies? I mean, the Interstate or Duracell or whatever is not going to make the car explode, will it?
#82
In fact the last Interstate I think it was, had a "Made in Germany" sticker on it. Saw that on one of the threads on here.
Want to start an oil thread? It would be far worse and based on conjecture.
#84
FWIW, now that I know that the OEM Banner (Porsche) battery is an AGM, I would not have a problem with purchasing a replacement battery from Porsche.
In Canada, we always pay 35% more in CAD due to the USD exchange rate. Plus, since we don't have the population and sales' numbers, add another 10% - 15% on top of that, then add a 5% for the Liberal government's corruption & collusion needs and you end up with a Porsche AGM battery being sold by the dealership at approx $400 + 15% (taxes). But we are used to being exploited...it's the Canadian way.
However, I refuse to pay $170 per hour to have a it installed...there I draw the line.
The aftermarket high end AGM batteries in Canada run upwards of $375 CAD + 15% tax. So in the end, I don't mind buying from the Porsche dealer parts' department and drinking their free caffé latté. It gives me some "face-time" with them and provides indulgences for future requests.
Gas
#85
Does anyone with a 991.1 use this battery? There has been discussion at the 958 forum that this battery is made in Germany by the same supplier of Porsche batteries:
AutoCraft Platinum AGM Battery, Group Size H8, 900 CCA
#86
Also note that it states "Marketed by Interstate Batteries" and not "Manufactured by" just above the bar code sticker.
#87
I have been doing some research both here and in the 958 forum. It looks to me that Porsche has been putting different size batteries in the 958.
Here, Lexvan's link to the self installation thread shows a 70ah, 760 CCA battery, while IXLR8 shows a 80ah, 800 CCA battery. So, I think a 95ah, 900 CCA should cover all bases
#88
If you have trouble starting, it is either a tired battery, a charging system not performing, a wiring connection issue or the starter. Pointless going bigger...your choice.
My friend's 997 was ultra slow to start when hot. Installed the much talked about on RL wiring harness. That wasn't it. New battery even though it tested good. That wasn't it. It was the starter. Faulty starter which I rebuilt and is a spare now.
#89
Sounds like he was trying to do you a favor by charging you about $800 for a freaking battery. Crazy. Buy an AMG battery and put it in yourself. Save about $550. Take the wife out to an expensive dinner and then buy her a gift too for being such a good wife. Or buy the kids a nice holiday present. This programming stuff is just a scare tactic to separate you from your hard earned money.
Your SA sounds like a grinch wannabe.
