This CTEK?
Old 12-09-2018, 07:37 AM
Tampa991
Tampa991's Avatar
Default This CTEK?
This model will work right? If not can you point me to the right one on Amazon?
CTEK (56-158) MULTI US 3300 12 Volt Fully Automatic CTEK (56-158) MULTI US 3300 12 Volt Fully Automatic
Old 12-09-2018, 08:24 AM
Semitone
Semitone's Avatar
I have the CTEK 4.3. Works great for my three Porsches. You might want the optional cig/12v plug so you can charge through your outlet.
Yes, the one you chose will work. Without going through the spec sheet it looks like the only difference between this one and the 4.3 might be the information display and the 3300 might be a lower power unit. ( 3.3 amps vs 4.3 amps?)
Old 12-09-2018, 08:27 AM
Mark993TT
Mark993TT's Avatar
I have the CTEK MXS 5.0 with the cable attached directly to the battery (car closed and locked).
Old 12-09-2018, 08:37 AM
Penn4S
Penn4S's Avatar
Received 1,330 Likes on 750 Posts
I have the same charger with the footwell outlet adapter. Good charger. Got it on eBay here.
NEW 12V Battery Charger Maintainer fits Porsche 911 Boxster Includes Cig Adapter
Seller : woodyscustomshop (27125 ) 99.9% Positive
Condition new
Price:US $79.99
Old 12-09-2018, 08:38 AM
Rennolazine
Rennolazine's Avatar
It needs to have snowflake mode and 14.7 V charging capability for the AGM battery. Looks like the 3300 model has 14.7V and 3.3 A on snowflake mode. The 4.3 model has 14.7V/4.3A, but also has a pulse charging setting for long storage. That's why I went with that one. The 5.0 is even better but figured I would get the cheapest one that worked for sure.
Old 12-09-2018, 08:53 AM
Tampa991
Tampa991's Avatar
Ok I will look for that one...I am going to use the direct battery connection.
Old 12-09-2018, 08:54 AM
Rennolazine
Dont need to. There is a lighter plug adapter for $10 on amazon.Easy peasy. Just make sure to lock the door and it wont turn off
Old 12-09-2018, 08:57 AM
Tampa991
Tampa991's Avatar
Old 12-09-2018, 09:08 AM
Rennolazine
Yes with the adapter 56-263. Clips right in and door closes without issue. Should work in passenger footwel or smoking package plug.
Old 12-09-2018, 09:44 AM
Porsche_nuts
Porsche_nuts's Avatar
Received 1,184 Likes on 711 Posts
It does not have to be a ctek, any battery maintainer will work - you don't have to spend $70 to maintain your battery.
Old 12-09-2018, 09:57 AM
Tampa991
Tampa991's Avatar
Can you recommend a model that is sold by amazon?
Old 12-09-2018, 10:30 AM
Porsche_nuts
I have been using this for years on my Porsches - no issues whatsoever.
https://www.amazon.com/Battery-Tender-021-0128-Maintain-Damaging/dp/B00068XCQU/ref=sr_1_6?s=automotive&ie=UTF8&qid=1544365614&sr=1-6&keywords=battery+tender https://www.amazon.com/Battery-Tender-021-0128-Maintain-Damaging/dp/B00068XCQU/ref=sr_1_6?s=automotive&ie=UTF8&qid=1544365614&sr=1-6&keywords=battery+tender
Also, hear that Noco is good, but do not have experience with it as a maintainer, but I do have a Noco Genius battery pack, which is great.
https://www.amazon.com/dp/B004LX3AXQ?aaxitk=uB.W8CY1Hi-lzXS7Jx-5ag&pd_rd_i=B004LX3AXQ&pf_rd_p=3ff6092e-8451-438b-8278-7e94064b4d42&hsa_cr_id=3562884720301&sb-ci-n=asinImage&sb-ci-v=https%3A%2F%2Fimages-na.ssl-images-amazon.com%2Fimages%2FI%2F91BSYy8KITL.jpg&sb-ci-a=B004LX3AXQ https://www.amazon.com/dp/B004LX3AXQ?aaxitk=uB.W8CY1Hi-lzXS7Jx-5ag&pd_rd_i=B004LX3AXQ&pf_rd_p=3ff6092e-8451-438b-8278-7e94064b4d42&hsa_cr_id=3562884720301&sb-ci-n=asinImage&sb-ci-v=https%3A%2F%2Fimages-na.ssl-images-amazon.com%2Fimages%2FI%2F91BSYy8KITL.jpg&sb-ci-a=B004LX3AXQ
Old 12-09-2018, 12:40 PM
kuma1416
kuma1416's Avatar
I have this exact model , hook it directly to the battery and it works fine. I don't know what the snowflake symbol means, I just put it on the car symbol and it seems to work .
Old 12-09-2018, 01:30 PM
Hurricane
Hurricane's Avatar
I use the CTEK 7200 and it works great. Any of the models in this thread would work well for you.
Old 12-09-2018, 02:29 PM
Fred R. C4S
Fred R. C4S's Avatar
Quick Reply: This CTEK?
