Burmester Tweeter Connectors
Old Nov 19, 2018 | 03:08 AM
gdwiggins999's Avatar
gdwiggins999
Default Burmester Tweeter Connectors
Anyone know the part numbers for the proper connectors for the Burmester dash and rear tweeters? Upgrading my base stereo to Burmester and want to do it properly. I already have the matching connectors for the midranges and woofers.
I'm installing the entire system including both amps; I know the head unit may refuse to talk to the Burmester amps without Porsche permission; my fall back plan is to use the NAVTV MOST adapter with an aftermarket receiver and ditch the factory head unit (it's only a matter of time before it refuses to talk to my phone, old maps, plus I have one of the old 40GB units). The Burmester amp is absolutely NOT a plug and play replacement for the Bose amp for those of you considering an upgrade; one connector on the main amp is completely different and the one that fits has a mostly different pinout, plus you need new wires for the tweeters all around.
Thanks, David
