Auto/Start stop button
Here's a question for anyone who has the T-Design memory module. I understand the factory programming of the memory module is supposed to be A/S/S off. Should I expect the A/S/S button be illuminated when I start the engine? I just installed the module on my 2017 Carrera S and when I start the car, the button is not illuminated. All the buttons work when I press them manually: PASM, A/S/S, etc. So the A/S/S button illuminates when I press it manually just as it did before installing the module. What am I missing? I thought the module would make the A/S/S button illuminate with the remembered setting. Am I wrong in expecting this?
^^^ The buttons are supposed to be as you left them when you turned the engine off. So if the Auto Start/Stop button was illuminated when you turned the engine off, it should be illuminated when you turn it back on. If that doesn't work, take a look at the last part of the written instructions. It says to open the door, turn on the ignition and press each one of the buttons 3 times with 1-second intervals between presses. This might be an initialization process needed to enable the module.
