991 Porsche Fitment
A potential problem with a 10" wheel on the front (regardless of the offset and clearances which is of course important) is the recommended tire width for that wheel is 265 or 275. You'd be significantly changing the handling bias of the car and make it much more oversteer prone, unless you increase the rears proportionally. Just something to consider.
