Broke down and put the winters on HRE ff15 with sottozeros. Figured they need a few hundred miles on them to break in before conditions get hairy. Will take better pics after the next wash.
Looks awesome. These are the exact winter wheels I'm putting on my C4S. I believe you have a NB, what are the wheel off sets? Do the wheels sit a little deeper? I wonder if I need to put spacers in rear for WB,
Thanks! These are for NB but def more aggressive than stock in back (flush with my car). I cant remember the exact offset off hand but you will likely need spacers especially if you have RAS.
edit:
20x8 / +50
20x11/ +60
edit:
20x8 / +50
20x11/ +60
exact same.
Winter tires for 4S front should be 49, so 50 is perfect. Rear should be 56. 60 would work just fine but 5mm spacers might be perfect.
anyone know exact specs winter wheels and tire for a T with RAS?
Wheels need to be 20's if you have RAS, as others have said. You can check suncoast website for OEM specs and willtheyfit.com to see how much it will change with aftermarket.
PS They only make winter tires in 295 size in rear.
Heres a better pic of mine on 20s today (I have RAS).
