Thoughts on my GT3 winter tire set up?
Why don’t we just trade cars for the winter. I’ll return it to you when it warms up in NY. Your GT3 will be happy over the winter in Atlanta. You will appreciate it even more after driving a base Carrera.........
i find this hard to believe! I really don’t like 305
on my 11.5” Sport Techno wheels. It would fit better w 315 or 325! I am amazed that Porsche puts a 305 on a 12” wheel, but a 295 would be really crazy imho! But some aftermarket wheels or some Pcar wheels in 8-8.5” front, 11” rear and put 235 F and 295 rear!
much better set up for winter!! GL.
Some 295s are wider than other 295s.
I bought these from Tire Rack, had them mounted on my 2015 911 4s factory wheels this past Friday. Drove all weekend and I'm very happy with the purchase.
I could not be more pleased. I too have no plans to be in the snow, just wanted a compound more suited for cooler driving temperatures and rain.
I have and decided to go with a set of the new bridgestone all seasons (980AS). Actually they are the only ones that fit so it wasn't really a decision! I really wish someone made a winter tire in matching sizes for the GT3. I've heard of lots of people running 295s without issue, but since I don't plan to drive in snow (only cold temps), I'm hoping that these will be sufficient. I'll let you guys know what I think once I get them on the car.
In cold weather without snow, All Seasons should have better grip than winter tires. Winter tires sacrifice wet and dry traction to get better bite in the snow, with bigger tread cleats, but less rubber surface area contacting the road. So All Seasons should have better grip on wet and cold dry pavement.
I don't believe this is accurate for high performance winter tires.
I ran 295 on a 12" rim last winter on my GTS, no issues whatsoever, sure dosen't seem to be overstretched.
I keep reading how some won't do it but I really don't know what the reasons are.
Haven't seen any technical reasons not to, just peoples comfort level, but what's informing these opinions?
@Damon - so I was just told by tire rack you are not getting any 20" 305's in for Michelin Alpin PA4 or Pirelli Sottozero serie II this year (only 295's)- which means any of us with a 20" 11.5+ rear wheel need to get new 11" rear wheels (well and matching smaller fronts) or try and source the 305 rear elsewhere, correct?
or drop a size to 19's - which still means new wheels.
I was going to use my stock Porsche 20's for Winter and get new wheels and tires next summer. But now I need to rethink my approach.
You either have to get new winter wheels or go with an all season tire like the bridgestone 980AS. Unfortunately no one has them in stock in the 305/30R20 size!
Welcome to the club. There are no 305/30R20 winter tires available for our 12 inch wheels other than the sottozero 3. The problem with the Sottozero 3 is that they don't make a matching tire in 245/35R20 to fit our front wheels (or at least I can't seem to find it anywhere). Tire rack does have the Sottozero 2 in 245/35R20, but I was told that you shouldn't mix the two tires. That does make sense to me but I'm not sure what could happen if you did.
@damon@tirerack.com , what do you think? Could we mix up the Sottozero 3 on the rear and 2 on the front and be better than running all seasons?
Forget snow and ice and the fact that cold temps kill summer performance tires how cold a temp can one drive summer tires without driving hard or aggressively as the car was designed for. I read about the summer tires "cracking" and of being damaged, but not max low temp.
I was told the same thing about mixing tires. There is an OLD article on their website about mixing Series II, but nothing across Series. See here https://blog.tirerack.com/blog/colin...g-winter-tires
