Should Rotors be cleaned? Drums?
Old 10-14-2018, 04:11 PM
kage65
kage65's Avatar
Default Should Rotors be cleaned? Drums?
Are rotors supposed to be cleaned at all? What about the inside of the wheel ( drums) ? Tks
Old 10-14-2018, 04:18 PM
koala
koala's Avatar
Rotors? They get cleaned every time you brake.
Wheel barrels? Yes. Best low-maintenance way is to clean them up really well and then ceramic coat the barrel (and the wheel face) so that they wash off easily in the future.
Psorcery
Psorcery's Avatar
I bought a huge jug of Sonax wheel cleaner which I use to soak the wheel, rotors and calipers. I also used a brush to swirl everything around and get into the small nooks/crannies.
I personally dont believe the rotors are necessary to wash the way I do.
Old 10-14-2018, 10:30 PM
okbarnett
okbarnett's Avatar
yes, you should wash out all the brakes and suspension parts. Take wheels off, wash everything and dry with air
Old 10-15-2018, 07:46 AM
LexVan
LexVan's Avatar
Received 5,388 Likes on 2,509 Posts
Yes, and yes.
I use a MasterBlaster. First, I blow out the rotors and calipers while everything is dry. After the dust clears, , I wash everthing with just car soap and water (a properly coated wheel [RejeX Wax or Optimum Gloss Coat] does not need a fancy wheel cleaner). Then blow dry with the MB.
Old 10-15-2018, 10:44 AM
911boy
911boy's Avatar
I've never used/needed a wheel cleaner ....ever. If you wash at reasonable intervals wheels are simple to clean IMO. If you don't clean the barrels regularly you could end up with balance issues. Rain cleans brakes............
Old 10-15-2018, 06:05 PM
3Series
3Series's Avatar
Supposed to, no. It just depends on what level of clean you want. If you want really clean rotors, just replace them. At $100/rotor, you could change them out when rinsing with soap and water don't clean them to your standards anymore. Joking, but not really. It depends on your OCD for cleanliness. I'd rather replace rotors than try to clean them to perfection.
Old 10-15-2018, 07:30 PM
subshooter
subshooter's Avatar
Received 2,143 Likes on 982 Posts
OMG! Lex's wheels look like new....and I know how many miles he puts on his car too. Wow. I need to get busy.
Old 10-15-2018, 08:18 PM
Al.Fresco
Al.Fresco's Avatar
Don't fall for it. He Photoshops those just like he does the pics of the WeatherTech girls!!!
Old 10-15-2018, 08:21 PM
vodkag
vodkag's Avatar
LMAO!
I usually wash the inside of the wheel and the brake caliper with just soap, probably every other time i wash the car.....
Old 10-15-2018, 09:28 PM
DBH
DBH's Avatar
Same, except every time I wash the car. I use the soap bucket I've just washed the car with and an old wash mitt. Get in there, swish the mitt around, rinse with a hose. Takes a couple of minutes per wheel. I also wash down the tires and inside of wheel well as well while I'm down there. Oh, I don't do the rotors. Let the brake pads do that.
Old 10-15-2018, 09:31 PM
LexVan
LexVan's Avatar
If I only knew how to use photoshop, I would have rotated the crest to point towards the value stem.
Old 10-16-2018, 01:52 PM
wforider
wforider's Avatar
Dam made me look...
Old 10-16-2018, 02:58 PM
tgavem
tgavem's Avatar
Anybody use WD40 ?
Old 10-16-2018, 03:04 PM
Guards_Red_991
Guards_Red_991's Avatar
Originally Posted by tgavem
Anybody use WD40 ?
I use WD40 for a lot of things, just not on my brakes. Are you trying to avoid instant rust build up on the rotor's surface?
I wash my wheels, brakes and wheel wells at the end when I'm done washing and drying the car. Sometimes I do it the next day.
Quick Reply: Should Rotors be cleaned? Drums?
