Door squeak
Door squeak
Door squeak I think this topic has been covered before. Has anybody found the solution to the door squeak? I saw this product and was wondering if anybody has used it
https://www.suncoastparts.com/produc...20Ends%20Soon!
TriFlow sprayed deeply into the door fixed it for me. You can't really see what's making the noise, you just have to aim the sprayer tube and hope you're hitting the right spot.
Lithium grease is probably the right thing to use, but good luck getting that where it needs to go.
wd40
I fixed mine by spraying wd 40 down the hinge inside the door. annoying that a car with 8k miles would have this problem and need new lid shocks in the same month.
