A/C Drainage Tubes
A/C Drainage Tubes
Looking to inspect my A/C drainage to see if they are clogged. Anybody know where they are on the 991. I am assuming they are somewhere around the front wheel wells?
I have owned my 991.2 for about 6 months and have been using my air continually and never have seen any puddles under the vehicle in the garage or anywhere else. My vehicles in the past have always dripped water so I am also confused about this.
Open the sunroof and see if there are drain openings (typically in the front corners of the sunroof drain channel). Get a long piece of flexible copper wire with plastic insulation and feed the wire into the drain openings. Check under the car after every foot of wire that is fed into the drain openings. At some point, you will have your answer.
