CARBON build-up in engines
#46
There’s no way to prevent carbon in an engine, I don’t care what you’re reading.
Techron is badass, it’s used by premier engine builders. I’ve used it when I put together motors I’ve built in the past.
#47
In all the years we've tracked 987.2 engines, we've never seen any buildup in the intakes, however there are contributing factors to buildup. An engine that is tracked sees lots of high rpm use with high port velocity. We've also run Driven XP9 in all of them that holds it's viscosity better than street oils (doesn't vapor off). The oil is also changed after every event.
On a street car with extended oil change intervals, fuel dilution contributes to a loss of viscosity, which increases the amount of oil consumption. The thinner the oil gets, the more ends up back in the intake via the air/oil separator. All that can be done to minimize this is running the oil level a little lower in the engine (not filled to the max), using an oil with a higher HTHS viscosity (M1 0w40 barely comes in a a 40 wt), and change the oil more often. Starting with an oil with a higher HTHS viscosity with a shorter OCI will reduce the effect of fuel dilution common to GDI engines.
When regards to fuel additives, they won't clean the intake port buildup, but depending on injector placement, it can help with some valve cleaning. What is important is that the fuel additive being used uses polyetheramines (PEA). That's the most effective fuel system cleaner you can use.
Manufacturers are indeed now going back to mixed port/direct injection, port for low engine speeds and direct injection for high engine speeds, both for port cleaning and also improved efficiency.
The following 2 users liked this post by Charles Navarro:
desmotesta (04-13-2020),
happychappy (04-12-2020)
#48
Mr Navarro,
Thank you for your insight. Can you elaborate a bit more on running a lower oil level in street cars in order to maintain higher viscosity? It seems like lower levels would thin more quickly than higher levels, taking into consideration the product being used is already less susceptible to fuel thinnage.
This is very interesting...
#50
Mr Navarro,
phefner (04-12-2020)
#51
OK, still confused... Sorry! And don't feel like you have to explain of you don't want to, but wouldn't having less oil in the reservoir mean more air?
#52
This is interesting. I tend to time it to run down my gas right before the oil change. After the oil change I refill the gas with the Techron. The belief behind this the oil is fresh with the treated gas. Then again, what do I know.. just going by what I thought it makes most sense..
#55
Since the AOS puts a vacuum on the crankcase, oil laden air is sucked out of the crankcase into the AOS. Theoretically, all the oil gets separated, but it doesn't. Some of that oil makes it's way into the intake and is consumed by the engine, leading to deposits in the intake.
#56
The engine has a wet sump. Like with most wet sump engines, running the oil level closer to the minimum oil level, especially on track, reduces the amount of windage in the crankcase.
#58
Nope. The stock AOS works very well. Eliminating the AOS and operating the crankcase at ambient air pressure would reduce ring seal as the rings are low tension and require the application of vacuum to them for optimal sealing.
#59
Thanks Charles, I'm the 2nd owner of this car and that's what I've seen on the valves after 115k km by the previous owner. in this case, I would assume that its because of all his daily driving activities, instead of hard driving on the track.
So for the owner who does mostly daily driving, and the occasional track day, would you say that some form of cleaning is required, and if so, is walnut blasting preferable over other methods?
#60
d-- (03-08-2022)
