It's called a symposer. It is a tube from the inlet tubing that attaches to a diaphram (to avoid the smell of fumes) then to another tube that terminates in the back bulkhead just below the rear window. If you pull the carpeted panel just below the rear window you can see the tube where it inters the cabin. Unlike BMW where they pipe false sound through the cars speakers the Porsche unit is real engine sounds.
Thanks for all the timely replies! I had known that about my 135i, which I thought was pretty lame, but wasn't sure about the P cars. Mine is a 1012.5 CS with the PDk and PDCCw/ PASM, Would the cabin be quieter with the "symposer" disconnected??
Yes. There are some hacks out there to make it quieter with a ping pong ball or spray can top in the symposer tube and foam on the baffles (or whatever they're called) on the top of the air box if that's what you're trying to do (most of us want more noise...lol)
This video is for taking off the rear bumper but the guy then removes all his "quieting" hacks.
I can’t figure out why the symposer is necessary. These cars don’t exactly mute road noise. I wonder what the sound difference is if you mute the tubes? I wouldn’t plug them, just curious if it makes any difference considering the limited sound insulation in a 911.
