Alignment with tire change?
Old 07-23-2018, 11:59 AM
phs0316
phs0316's Avatar
Well,, Speaking of Alignment, I feel like my steering wheel is slightly no centered,,., is this sign of alignment?
Old 07-23-2018, 01:23 PM
Sidvicious7
Sidvicious7's Avatar
I agree a vehicle my not require an alignment unless there are wear patterns on the tire/s or questionable handling to warrant so. Some Indy shops will inform you there is a minimal charge or not to put the car up on the rack; if the alignment is out of factory specs they recommend the option to align or not (street or track alignment) your call.
Old 07-23-2018, 01:25 PM
LexVan
LexVan's Avatar
Received 5,402 Likes on 2,513 Posts
Yes.
Old 07-23-2018, 01:27 PM
wareaglescott
wareaglescott's Avatar
Has the steering wheel ever been removed from the car? It could have been put back on out of whack,
Old 07-23-2018, 01:41 PM
arter
arter's Avatar
They would have to rebalance the toe on each side to recenter the steering wheel.
Old 07-23-2018, 04:50 PM
Bud Taylor
Bud Taylor's Avatar
Default +++
Are current tires wearing unevenly
Does car pull to right or left
Did you hit anything.
If the above answers are no then no. Dealers love uncomplicated services that are not needed.
Originally Posted by 4pipes
I go to a local well respected Porsche race shop for all my cars’ tires. They do not recommend an alignment if the car is not pulling or exhibiting uneven wear. The dealers will automatically suggest an alignment. I do not do them.
Old 07-23-2018, 04:55 PM
LexVan
LexVan's Avatar
Getting an alignment done next week. On special for $300. First alignment in 59,000 miles.
Old 07-23-2018, 08:14 PM
minthral
minthral's Avatar
Typically dealers and shops say only do it when required (suspension work) or there is a problem (uneven wear or handling funky or you recently hit something).
Cars can pull a direction is due to low quality tires. Its normal to have hold wheel slightly off center when going straight due to crown in the road for drainage or other imperfections. A lower sportier suspension accentuates this.
Quick Reply: Alignment with tire change?
