991.2 C2S What are my rear spoiler options? Wheels?
Car is in for PPF, going stealth Xpel on the black car. I want to add a spoiler wing to rear. What are my options? Ive been searching and all I see is the Duck or Tech art. Any others?
As for wheels, can I only use 20 inches with the rear wheel steering?
Not sure of tail options, but am certain you can go 21” with rear steering (I did this as did many others in the forum).
Width can be a factor with rubbing if you go too wide. I went a bit wider with 325 tires on the rears (I don’t recall the width of the wheel itself, I believe I went 1/2” wider than stock).
I have a TTS, not sure if tire width limitations are same on non-TT/TTS. I would be certain 21” diameter is ok though.
Likejy a forum on here already with details if you search.
Lots of great wheel options out there, look forward to seeing it complete.
Porsche doesn't recommend putting aftermarket spoilers/wings on a 991.2 Carrera since it will interfere with the flow to the intercoolers underneath the stock spoiler and those are vital to the car's power. The claim a loss of as much as 80 HP without proper intercooling.
They do have a cool mini-duck (more of a micro) option that comes with the Sport Design aero... but that is as much as is recommended.
Cool! I didn't know anyone had come up with a viable 991.2 wing solution yet, but it makes sense that TechArt would do one. Thanks for the good info... I'm sure its worth a lot to OP.
BTW, a related aside. I was just out to lunch in the car and got reminded about how early the car will deploy the spoiler on a 991.2 when it's hot outside. We've been getting into the high 90s a lot. If I call for almost degree of "fun" acceleration the spoiler deploys... even at fairly low speeds. I'm assuming it is due to the outdoor temperatures as I didn't notice the car being quite so aggressive with deployment back in February.
If you have AWS (all-wheel-steering), I understand that most 19" wheels with barrels large enough to clear the bottom suspension attachment point. It's hard to get a thin sponge through that gap when cleaning the barrels on 20" wheels. Someone has posted one aftermarket option that will just fit in some other thread addressing wheels and AWS but I don't recall what that was.... maybe Forgelines. You'd definitely want to check with the manufacturer.
If you get the ET 40 version, you will need a 7 mm or more spacer to prevent contact if you track the car
( there is a change in inner diameter of the rim just outboard of the tightest gap to the RWS knuckle).
Gap is 3-4 mm. They have an 50 ET version that should work without the spacer.
If you dont track the car, you probably won't need the spacer.
Ran without the spacer at Chuckwalla successfully, but the long, high G turn at AutoClub caused the rim to flex inward enough to make contact with the knuckle..
Adding the spacer fixed that.
I have used the OZ HLT 11x19s with the RWS on my 991.2 GTS.
Thanks for the input. Got a call today that the Endurance racing decals are very hard to get off and they leave some etching in the clear coat. Im working on a warranty claim for having them removed and the paint corrected. I will likely just take the decals home and opt not to have them put on. Hopefully Porsche comes thru for me, as these decals are horrible quality.
I was thinking the only decent wing was the tech art, but I like the turbo S style as well.
As for wheels, I want to get another set for track days. I likely will only be able to make 4 days this summer, but I think id like to have better tires than the pirellis. I did searching but didnt see anything definite to whether or not i have to run the 20s to get clearance w RWS.
I wanted a spoiler on my c2s but didn’t want to go big or remove the retractable wing so I put a spoiler from spoiler Nation on, I don’t track the car it’s not a daily driver I just wanted a little something to flair up the back end, I’ve gotten crap from others on this site regarding the wing will act like a air brake and loss of gas mileage and bad aerodynamic, but I haven’t notice any of those, I like the way it looks and to me that’s all that matters.
Hey LamboMike58 -
IMO that spoiler looks great! I'm considering it for my 2017 Ice Blue Metallic Cabriolet. Are you still happy with it? Did you install it yourself and, if so, how (tape or bolts)?
Thanks!
2017 Ice Blue Metallic 991.2
Thanks!
OEM Sport Design
If you want that clean look
Wrtflyr (09-15-2020)
