Anyone know, ballpark, how long brake pads last?
45K on the original pads/rotors for my 2014 991.1. Included a lot of back road driving and countless near ABS braking on the Autobahn above 150 mph when someone pulls into the left lane on you for about 2.5 years of driving over there. Happened once at 190+ mph and I was on them hard and felt pulsing...stopped in time to avoid nastiness. Can't believe how perfectly straight the car slows at those speeds and never felt spongy. That being said, I am just waiting for the light to come on. Dealer says it's getting close.
Remember that on the models with PTV (torque vectoring) and its usage of the rear brakes, if you spend a lot of time driving hard in the twisties the back pads have been observed to wear just as fast as the fronts (or faster if you are really pushing it???).
Also, you don't really have to measure the thickness of the front rotors. Along the edge some of the "holes" are not drilled all of the way through and are wear indicators. Once they disappear the rotor is under spec.
regajohn (02-01-2024)
As for wear, I'm sure many P-car drivers get exceptional mileage on brakes. On the average road trip, good drivers apply brakes about a tenth as often as the average driver.
I understand that it's your first performance machine, which is great.
Do you really think that having to apply the brakes more frequently in normal driving indicates that you are a great driver? Please explain how applying the brake very frequently in everyday driving indicates that you know what you are doing.
Just trying to learn from the experts!.
Rotors are considered disposable items, same as brake pads. On a car of this caliber and expense, you should either re-surface or replace the rotors with a new set of pads. You want a fresh mating surface for the new pads.
I'm just coming up on 80k miles on my 2013 CS and am still on the original pads. The miles were predominately from my daily commute to work through Houston's rush hour traffic, 30 miles each way. I do tend to use engine/transmission braking though, but do also like to brake late and hard for sharp turns.
Many moons ago I would spend miles and miles "bedding in" new pads on old discs (rotors) on a rally car to get them to work.
FWIW, I am not going to throw out rotors if they are within spec. I do not skimp in the slightest on maintenance (I do it all myself), but I also do not see the upside in throwing money at cars. The rotors have a thickness spec from Porsche, and so long as mine are within it, they will remain on the car. There is no need to change pads and rotors together.
moxie (SF) (01-25-2022)
boxsterisgood (12-11-2021)
I'm going to be removing calipers and pads to apply anti-squeal paste. Can't take the squealing anymore. My car (an S), has 47K and the pads were last done by the PO at 28K. Is 20K around the typical service life of these? And does anyone have a thickness spec for S rotors?
