Radio station setting
Old May 8, 2018 | 10:15 PM
aduong's Avatar
aduong
Default Radio station setting
hi all, does anyone know why my radio keeps going to a certain radio band 103.3( Christian channel) in ne ohio when I do not have it as a preset and I never tune to it. My closest channel is 104.1 which is preset 1 and is clear signal. I even set channel preset to a different band to see if that stopped it but no luck.
every time I start the car even if I was on BT audio or a preset station when I turn it off still goes to 103.3...
what setting do do I need to tweak to Go to a preset etc?
Old May 8, 2018 | 10:44 PM
Norsk's Avatar
Norsk
Better get right with God, brother.
Might not be a coincidence.
Old May 8, 2018 | 10:50 PM
Al.Fresco's Avatar
Al.Fresco
Not sure if that info saves to the key, but have you tried saving your setting to the key while on a different radio station to see if it becomes the new station at start up.
You may also want to check your save config settings on start up in your multi function display.
Hope you figure it out.
Old May 10, 2018 | 01:25 PM
DBH's Avatar
DBH
Old May 10, 2018 | 06:11 PM
jackporsche09's Avatar
jackporsche09
This could be the 2nd coming that we have all been waiting for
