Smog rating of the 991.2
Sustainability. It is not a dirty word even at Porsche.
https://newsroom.porsche.com/en/sustainability
If it meets government emission regulations, and I can legally drive it on the street, that's good enough for me.
Of course. Don't install cat bypass pipes. But I still am not understanding the point of this public self-shaming. If you don't like the emissions of your 911, get a different car. What is there to discuss?
Besides the fact that even vehicles that rank only 1 are much cleaner than average emissions from a decade ago, the numbers of vehicles is also significant. Porsche sold 8900 911 models of all variants. Honda sold 700,000 Accords and Civics in 2017. We could run our 911's all with unrestricted engines and not even make a blip in the total emissions of all the Hondas.
Trump will get the EPA to relax standards. He's already going after CARB.
So you discovered this emissions "issue" with the 991.2 before or after you bought your 2018 C4S?
If it was the latter, I think you have bigger issues to worry about (with yourself) than emissions standards..
If it was the former, then the person you need to speak with is in the mirror.
Must have something to do with 400hp and 0-60 in under 4 seconds. I traded my V8 Mercedes and Twin V8 Cruisers Yacht for the 911. I used to use more gas in one weekend in the boat than a full year in the 911. I am much happier with the 911 than the boat and can truly claim a lower carbon footprint.
Eh, all comes down to how you use it.
Yes, high emissions compared to a car of similar weight and size that emphasizes fuel economy (as most do). But, VERY low emissions against cars of not long ago—even those that made less power. Also sips gas compared to Porsches I've had in the past, and the old one in my garage.
As for at delete, well, what a bummer. And for no useful hp gain.
One can like something a lot and still be critical of its shortcomings. How hard is that to get? I will ignore the asinine comments posted by those who can't stand to read anything negative about the 911.
Porsche went to turbo sixes for emissions. They did improve the CO2 emissions (in theory) somewhat but apparently not (the more stringent) smog-causing emissions. So the purpose of the engineering exercise was probably for performance gains and not emissions as stated by Porsche. And to get around the pesky taxes levied on engine displacement in certain countries. What I can conclude. Nothing wrong with that. But other high performance small cars do seem to fare somewhat better. Just something to remember when going shopping for a high performance car if one cares for such things. Did I know about the emissions before I bought my car in 2017? Only the fuel economy numbers but the smog ratings were not published for 2018 cars. Would it have affected my decision to buy the 911? Honestly don't know. I may have kept my 13 Boxster S which did not see as much use as my 911 which is rapidly acquiring DD status. Am I regretting my purchase? Not really but I do wish it had better real world fuel economy & better emissions. Almost everything else is perfect for my driving needs.
Anyway, this was simply a byproduct of my interest in aftermarket exhaust systems. I could not find any information on how these systems affect emissions. Hence my interest in bringing it up. There is no reason to get bent out of shape by it.
As to the real world fuel economy, the 991.2 is clearly better than the 991.1, if the car is driven to exploit its greater low-rpm torque and taller gearing. Of course, if you belong to the 7th gear-is-unmanly crowd, or keep your revs above 4000 even in rush-hour traffic, you probably won't realize the improvement. In this regard, however, the 911 is better than the three competitors above, with a 5 rating, while the others are all rated 3.
SMOG rating system/criteria change every couple years or so.
With the drastic change in the administration, chances are the EPA also have a drastic change in their criteria for SMOG ratings.
Now, from an engineers point of view, emission levels are measured by the level of CO2 being outputted from the motor during operation.
A 2014 Carrera 3.4L outputs roughly 191 g/km of CO2.
A 2018 Carrera 3.0l Turbo outputs roughly 169 g/km of CO2.
Can't find the other levels (like n02, CO, etc) but I'd assume that those levels are also lower for the turbo car, than the N/A car.
http://www.emissionsfinder.com/porsc...dk-euro-6-35cc
The new Tier 3 ratings are indeed more stringent and where the 991.2 stumbles compared to some other cars. I thought these ratings were within a class of vehicles and if not, then it looks worse. Even some SUVs come across as better wrt emissions.
It is hard to compare smog ratings for the 991.1 vs 991.2 because the standards have changed.
Anyway, it is what it is. Again what got me started was aftermarket exhaust systems. Not sure how many would pass inspections and not trigger a CEL. Interesting.
Regarding fuel economy, I have seen about 26-27 mpg in highway driving in seventh.
Not to come off as aggressive or trollish, but what are you trying to get at with the emissions from the Porsche and exhaust systems?
I just looked at the figures for a 2018 Tahoe, a 2018 Carrera C2, and a 2016 Carrera C2. The Tahoe is far more inefficient, and pollutes a lot more than the Porsche. It also have a lower rating...
Genuinely curious as to what your stance is on this view, and your thinking behind your comments . I put a smiley face cuz I'm not trying to be a dick...
Interms of exhaust systems, modifications after the cats will not affect the output emitted by the engine. From my initial inspection of the system (was taking measurements), there are no secondary cat structures to be found...
This would indicate (to me at least) that the stream after the CATs would be of similar quality to that of the stream after the tailpipe.
From my research, Fabspeed X-pipe would be your best bet if you wanted more sound without affect the output levels. A 200 HJS cell CAT (like those found in performance CATs from Soup PP or Fabspeed) are going to scrub the exhaust gases to a level that is deemed acceptable by the ECU (hence the no CEL).
That said, they might not be scrubbing and outputting to the level that the EPA would like....
Personally, I really don't view on the same level as the EPA...so I probably will go sooner or later (probably sooner). But lets not get onto my views.
What I'm saying is, if you want more sound without effecting the emissions output of the car, then focus on mods after the cats. Shouldn't affect the levels outputted. Will definitely help sound, cuz that muffler seems quite effective imo.
Fair enough. I was trying to understand why such a poor smog rating on a modern engine. Yeah standards have changed but they have for all cars and SUVs. For example, Jaguar seems to be doing quite well wrt smog for both their cars and SUVs. I was surprised by the rating for the 991.2. That's all and a little disappointed. Not enough to sell the car and buy an F type. Actually even the big nand heavy Panny 4s with the V6 scores much better than my 4s. Something about the flat six design and the catalysts being used to scrub emissions seem to not be as effective as the V6s used by Jaguar and Porsche.
Regarding aftermarket exhaust systems with cats, unless I see emission data, it is just speculation. I was looking at Tubi but can’t find any data and don't want something worse than stock.. Fabspeed is way too loud for me. What other catback systems are there for the 991.2? Something not too loud.
