opinion on a 2012 991CS
Thanks!
Now my next question is spacers, i have a set of 8mm and 13mm coming off my 987.2S that I can use. Would that be a good fit for these 20in wheel?
They should be the same CB and bolt pattern right?
My 991.1 C4S with SPASM had HRE wheels that had offsets equivalent to 12mm front and 13mm rear. They worked just fine and looked really nice and flush. 12 was a bit on the aggressive side for fronts. I'd think you'd find 8/13 to be a good fit. Here's a couple of photos showing the positioning of the wheels at 12/13.
https://rennlist.com/forums/991/1061...s-install.html
I have 8mm and 12mm on my C2S. Info and photos in the link below.
