991,1 vs 991,2 GTS wheel offset
The 991,1 GTS have a 11,5x 20 centerloock wheel with ET48 in the rear
Is there a 991,2 GTS that have same offset but the new facelift wheels or do them all have 12x20 ET 63 in the rear ?
A good question, the 991.2 have 12x20 et63 and a track of 1544mm, so some 16mm less than the GTS 991.1 which has a track of 1560mm, however the 991.2 has 12" rears so 12.2mm wider so the outer lip of the rim is, I think -8+6mm =-2mm further inset that the 991.1
I have seen one member fitting et45mm 12x20, which look aggressive but not silly, for some reason the 991.2 doesn't look as inset at the back a s the figures suggest.
But is there a 991,2 Gts with the 991,1 gts offset apec on the facelift wheels or do ALL 991,2 GTS have the 12x20 et 63 wheel setup
on the rear
on the rear
