SOUL | 991.1 Carrera Base w/o PSE Valved Exhaust
Basic Sponsor
We're happy to announce our Valved Exhaust for 991.1 Carrera Base owners without PSE! The design mirrors our existing 991.1 Carrera Valved Exhaust with slight modification to the factory side mufflers to give your Porsche the exhilarating exhaust note it deserves!
SOUND: With valves open, the free flowing nature of the system allows for a Cup car inspired sound – greater volume with a greater amount of crackles and burbles on deceleration. This system is for those who want added aggression at the press of a button. With valves closed the tone is very reasonable and refined, drone is kept to a minimum while still allowing for the flat six sound to be heard.
CONSTRUCTION: Each system is made from mandrel bent T304L stainless steel tubing and features mufflers with fortified casings in the interest of durability. You can order this exhaust to suit your specific aesthetic desires – select the tips of your choosing. The SOUL system weighs roughly 6 lbs / 2.7 kg less than factory exhaust components (26.45 lbs vs 20.95 lbs, both without clamps).
BOLT ON AND GO: Each exhaust is tested in a fixture to ensure perfect fitment. Installation requires cutting the factory side mufflers to affix secondary exhaust tip outlets and installing clamps (which allows for reinstallation of the factory system if necessary). Thorough installation instructions are included in the box for a straightforward install that can be performed by most DIY enthusiasts. Valves are controlled with our included valve controller and optionally, HomeLink controls.
LIFETIME WARRANTY: Enjoy your Soul exhaust components with confidence on both the street and track as they are covered by our Lifetime Warranty! Our team will quickly work with you to resolve any issues or answer any questions that you may have.
NOTE: Installation of the valve controller requires removing rear bumper, locating and tapping a 12V switched power source, and installing vacuum lines. We highly recommend professional installation, for recommendation of your nearest SOUL installer please contact us.
In stock and ready to ship!
PRODUCT PAGE
Email: info@soulpp.com
Phone: 855-486-1400
IG: @soulperformanceproducts
PRODUCT PAGE
Phone: 855-486-1400
SOUL PERFORMANCE PRODUCTS
Quality Exhaust Solutions, Fair Pricing, and Outstanding Service
John Gaydos- Owner, Performance Specialist
Cell - (484) 883-6197
johng@soulpp.com
Jon Wheel - Marketing Manager
jwheel@soulpp.com
johng@soulpp.com
jwheel@soulpp.com
Basic Sponsor
Always glad to help! The piping for our tip is expanded on the end, slides over the factory piping, and is held in place with an Accuseal clamp on top. To put the stock piping back on you would use a Torca clamp - both ends slide in and butt up against each other and the clamp is tightened down.
