CTEK Porsche Battery Charger ?
#46
I just bought the Genius 1100 with the cigarette lighter adapter that they sell. I put the settings to cold and AGM. The red flashing for the 25% flashed and immediately became sold red while the 50% red was flashing still after 15 minutes or so. I am hoping that this time it works. The cigarette lighter adapter I bought on Amazon for the Battery Tender Junior did not completely fit the connection and there was a slight bit of space and the rubber cover did not fit it completely so I was not comfortable using it.
#48
Update. Now the green light is flashing and the red and the orange lights are solid. When it is maintaining the green light is supposed to be solid and all other lights to be off. I will keep it in the garage and see how it goes.
#49
I have a CTEK Multi US 3300 that up till now I have not used a whole lot. I am not driving my 991.2 much, at all, these days due to the situation ref COVID-19.
I would like to ask a few questions?
What's the longest (days) I should go before putting the car on the charger?
I placed it on charge today. I've only been up to get fuel once in the past 10 days. A picture of the charger is below. I assume after reading the manual this is more or less normal? I have it plugged into the center stack DC 12V smokers package via the 12V outlet adapter.
TIA.
Rich
TIA.
Rich
#50
I have connected it and keep it for a long time. I think the longest I have kept it and not driven it was for 3 weeks in January this month. Please bear in mind I am in Canada and it's very cold in winter.
#51
I also have a CTEK 3300 which I use on my 991.2. I connect directly to the battery with the capped end coming out near the passenger wiper. I find it much easier to plug in that way. I use the car indicator light on it and have never had a problem.
#53
Why not connect just directly to the battery and pass the cable near the passenger wiper were there a space in the rubber for this effect ? Really easy and you don't have to worry about the other connectors not working.
#54
Because the battery is under the drivers seat. It's not possible. The Cayenne is geared to use the cigarette lighter socket for battery maintenance.
#55
Wrtflyr (04-17-2021)
#56
I can use that under the hood for boosting and to start up but not for the maintenance when it's parked for a long time.
#57
I have a few chargers and one of them is an Optimate with the de-sulphating feature. Any opinions on whether or not I can use that feature IF I am using the cigarette lighter adapter?
Also, I'd like to chime in on how often to use a battery tender. If it's going to not be driven for two weeks I hook it up. That's my gig.
#58
I have 2 of them at home and 2 that are always connected to some Karts that we have with my son (picture attached). Karts can't charge the battery and that's the reason for having them connected 24/7. Batteries have really lasted if compared with other guys that just charged their batteries when they decide to go racing. In my 2 karts I haven't changed batteries in almost 4 years when the normal time is 2 or 3 years at the most.
I do travel a lot because of work so my routine is to connect my car every time I'm away from home for more than 3 days. Since I have permanent connections, it just take 1 minute to connect the charger and I'm a firm believer that my battery will last longer by doing it.
#59
Thank you very much. I tried that and it didn't work for me. So I asked Porsche and they told me that only the cigarette lighter socket will work. Mine is an older model. But this works now for me.
