Originally Posted by pdutta2000
(Post 14839300)
I don't have that dash rattle but I have squeaks that sound like 100 mice are having a party right behind my steering wheel. The dealer swears they can't re-produce but it's there every time I drive the car. I now crank the music up to drown it out.
I had a (very loud and annoying) rattle from almost Day 1 that I thought was from the dashboard on my 2017 991.2 GTS... dealer (Reading, UK) fixed it and said it was something to do with lubrication on the front suspension. I am no expert so I can't vouch for the accuracy of that. One way or another, the rattle disappeared.
Had similar rattle that I could not tell if was coming from the passenger side outer dash or the front of the passenger door. Was nearly constant but got much worse with deep bass notes of the stereo. Took it to the dealer a couple times and they did the TSB with the felt and all... no better. Later when I was installing Nick's (Musicar) group purchase DynAudio tweeter setup (HIGHLY recommended BTW!) I found a broken tab on the passenger side AC vent. I JB Welded it temporarily until I could get it to the dealer and that fixed it. They did go ahead and replace the AC vent...
Originally Posted by GregD
(Post 14839418)
That sounds like fuel tank cradle above... Does it vary based on tank level ? it was a cheap fix ! couple hundred $.
My rattles are the same with fuel tank full or nearly empty. Since the dealer attempted the fix, the rattles occur during moderate to heavy braking or when driving on rough roads.
Originally Posted by phx991
(Post 14815204)
Anyone have a rattle coming from the dash area that's this bad? This is pretty much constant. |
I have a very similar rattle in my 991.1
Did you end up solving the issue? |
