Can someone help me with a picture of the underside and how it is mounted? I'd like to see if there is a chance it is compatible with the #1 cars. Thanks.
What's with all the bizarre avatar pictures? You really got to get back in the game. I can tell you're getting bored. Good luck.
I just started a board position putting people with disabilities back to work in technology It's fun but certainly not the 80 hours of week I am used to.
That's cool. I've seen some cool stories like that on 60 Minutes. Good on you.
It's also interesting to see the data associated with hiring this demographic of diversity. The company I'm helping just needed someone that could have conversations with people with fancy titles and not have to beg for a meeting. It feels good to help a company that is actually looking out for their people and not looking for every possible way to screw their own staff.... like the last 2 publicly traded companies I was at that mer downright malicious.
Maybe someone with a lift can get some better shots, but here are some shots of various key locations . It appears it attaches with tabs that slip into a bigger part of a notch and then lock in when the lip is slid to the side. Let me know if additional photos are needed and what part you need a better view of.
Outer edge
Just in from the outer edge
And the locking tab mechanisms more towards the center (I lost track of the order as I moved toward the center, but I think you get the gist of it)
Here at the two part numbers: 991.1 is 991.505.525.01 and 991.2 is 991.505.525.04
There aren't a lot of pictures of these online, but here are a couple. The look very similar and attach in the same way. The only difference I'm making out in these images is at the very outer edge the newer 04 version seems to be a couple of inches long since those outmost edges stick out notably farther past the two square holes. It appears they are not a plug-n-play match.
