Get rid of PSE...and get the "axe murderer" instead?
I've love the stock PSE on my 991 C4S!
It sounds like a wonderfull orchestral arrangement linked directly to my cortex!
It's not just the multi layered crescendos, it also sounds "expensive"... the announcement of something sophisticated, fast and mean
However... I find myself going for drives with other enthusiast whom have Lambo's. Ferrari's, McLaren's etc and the 991 is just too damn quiet in that company... after which I find myself gravitating towards something louder.
A fellow reenlisted was kind enough to let me hear his AWE "in the wild"... and THAT certainly would hold it's own in the above mentioned company!
However, it may be a bit too much like an "axe wielding murdered" coming to kill you, rape your woman, sell your children and eat your pets
Fun... but too much?
Certainly will add a bit of drama... but at the cost of the sophisticate/refined aspect of the PSE?
Anyway, I've decided to give it a shot.
I have an appointment at TAG tomorrow to get the AWE system installed.
So... if I do like the axe wielding killer... the PSE system will be available.
If not, I'll put the PSE back on and hopefully will be able to return the AWE.
Kinda exited to see how it all works out.
Cheers!
Cheers!
Received 3,879 Likes
Well, good luck to you on that one. I think you're going in the wrong direction and should look at high-flow sport cats. Removing a Porsche Sport Exhaust system to replace it with an X-pipe is kind of going backwards.
Enjoy the drone....
Enjoy the drone....
I totally forgot about the inside , you had an AWE right?
I've tried a multitude of things... non that worked, sigh.
Even some of my own design, had access to fluid dynamic cad programs at one point.
designed the most beautiful multi resonance flows which should have had a self re-enforcing cascade effect.
Instead all the beautiful frequencies canceled each other out and all I had left was drone!
With all the positive feedback on both AWE and TAG I'm hoping it'll give me the sound/volume I'm looking for.
here's hoping you don't get to say "I told you so!"
Fingers crossed.
I had an FC RX7 one time where the hanger for the exhaust was broken and I went over a pothole and it managed to hit the ground and put a hole in the exhaust...now I'm not saying drill a hole in your exhaust, but if you want to increase the sound for a little while, you could always loosen up some bolts and let that noise come racing through!
I actually have the 991 as a "comfy" fun car.
For "the loud-ish weekend car" I've got an 12C but I hardly drive that anymore (electrical issues notwithstanding) that thing is awesome, great sound, little outdated styling still looks GREAT but... you need to do acrobatics to get in ( and especially out), not to mention the head splitting drone every time you go slow.
So, as long as you go fast and never get out... you're good
I know, getting old sucks!
I digress.... I love the 991 because I believe it can be both a semi "subtle versatile daily driver" and "a loud weekend car".
All the custom work has been geared towards that... now I just need the right exhaust!
That's a little too "Fred Flinstone" for me but, I get what you're saying.
I've had lots of different exhaust systems on different cars...
If I have to take another rubber mallet to all the clamps and fitting to find the rattles, farts and other mystery sound I'm going to scream!
So the thought of drilling some holes in the OEM PSE to get some more from it certainly would omit the aforementioned rubber mallet.
I have tried a more soficticated version of the hole drilling by doing actual mods to stock systems but non have worked out.
It certainly will be an option if the AWE doesn't work out... I'm persistent if nothing else!
Go for it! Louder the better. These N/A flat sixes are a mechanical symphony. PSE sounds amazing and very well balanced, but I can understand the lust to hear even more of said motor.
I have a Sharkwerks X Pipe on my C2. At lower speeds it’s civil, while at higher RPM’s it sounds brutal and raspy in the best way possible. It could certainly be even louder and I’d like it even more, but the sounds it makes at 3,500+ is addicting. Probably my favorite part of the car. There’s a crass rawness to it that I think PSE doesn’t have. It can startle people at downshift. I would also imagine it’s louder than PSE at upper RPM’s (I have to drive a PSE .1 C2 to be sure). Though not sure which is louder at lower RPM’s.
Oh good, that's just what I needed to hear.
Was starting to doubt myself a bit...
Reminds me I bought this 991.1 over a 991.2 purely because it's n/a.
Might as well go all out and scream it all the way up the rev-band.
Can always reduce the pipe diameter of the inner exhaust (after the valve) to get a more high pitched sound.
For now, I'm looking forward to try out the axe murderer
For now, I'm looking forward to try out the axe I murderer
“Ax murderer” is the PERFECT description for how these things can sound when uncorked. When I pass a car and there’s a wall or another car on the other side (for sound bouncing off purposes) with aggressive throttle, the car sounds absolutely brutal, like it wants to chainsaw slay whatever’s next to it. I love how uncivil it is when need be.
EXACTLY! The sound is why I wanted the N/A .1 more than the .2 so much as well. I can’t get enough of hearing it. I’d like it even louder, but I am happy with the balance. But considering sound is the chief gold mine here, make sure you get the most out of it via a volume level that properly satisfies you.
LOL axe murderer... chainsaw slayer... not the kind of thing one would associate with a 911
Boys will be boys!
It's not just the sound but also the power delivery and high revving, free flowing nature of the cars character that has me hooked on the 991.1
Plus, with the valves closed it's very, very civilized... until you open the valves and the axe murderer comes out to play
I'll post back when the exhaust has been installed.
Boys will be boys!
Boys will be boys!
I had a 991.1 4S prior to my current car. I chose to go with the Kline Iconel Exhaust. It is wonderful sounding and more like what you are looking for in the other exotics. It’s more expensive but you get what you pay for in build quality and sound.
Lambos and Ferraris aren't "loud" per se. They're exotic cars. They sound exotic. Distinctive. To try to emulate the sound of an Italian exotic car by throwing on an aftermarket exhaust system (in my opinion anyways) is sacrilegious. It will end up sounding like my neighbors Hyundai Veloster. God I hate that car. Wakes me up every morning.
Besides, the sound you hear inside the vehicle is nothing like what it sounds like outside. PSE sounds great when you hear the car pass by at speed.
