991.1 GTS Sports Exhaust Problem
HI everyone - I am unsure but I feel that occasionally on starting up the car ( often after a drive then driving again ) and engaging sports mode - that the exhaust note seems quiet as if sports mode is not engaged. However after driving for a while seems to come good. Am I imagining this or does this happen ? One theory I have is that it might be either sports mode not engaged at all or only the sports exhaust is without sports mode symphasizer... this being due to an aftermarket accessory I added which seems to interfere with the sports chrono clock some times. If not its a physical issue.
Thank you for any thoughts.
Otherwise loving my GTS - especially the engine/exhaust note.
Only started putting KM on it so still getting to know it better
Thank you Hurricane - Yes I am suspecting the same after reading the forum on it - I plan to disconnect my after market device which interferes with the sports chrono clock and if problem persists let Porsche know to look at the change over valves - which from my reading can affect both the sounds symposer and the PSE. I thought Porsche had got rid of this problem by 2015 models but perhaps not
Cheers
Cheers
