Replacement PCCB Calipers
#46
OE Front 6 Pot Caliper - Closed Top w/ Non Staggered Pistons
RB 6 Pot Caliper - Open Top with Staggered Pistons
Advantage:
1. Open top - Very easy pad change, no need to detach the caliper
2. Stainless steel pistons - Never crack, low heat transfer to brake fluid
3. Internal dust seal (same type as Ferrari F430 Scruderia) - Eliminate burnt out external boots
4. Staggered pistons - Reduce brake pad taper wear, extend pad life
5. Brake pads are same as ZR1/GTR - More choice in suppliers and compounds, save in maintenance cost.
Advantage:
