Debunking "the engine is on the wrong side" ....
^ Another advantage of the Cayman's space is the pass-through availability of the rear hatch. In my 987 Cayman S, I could fit my pop-up tent for track days through the rear hatch and rest the front of it on the passenger seat. Looking at the tent sitting outside of the car, you would never believe that it would fit.
My favorite reasoning for this by Porsche was that the rear engine design provided too much traction, prematurely wearing tires during racing. In other words, it's just too good, haha and they need to level the playing field! While true about the traction, it's like come on, who's buying that.
Defining right/wrong or best/worst engine placements depends on what you want a car to do.
If you want a quiet, safe street car to drive one-handed while sipping coffee, eating a sandwich and stroking a dachshund, put the engine up front.
If you want a pro-level race car that will only be driven by pro-level drivers seeking the ultimate laptime, then put the engine in the middle, preferably just ahead of the rear axle (and remove everything else except the fuel tank, brakes and some manner of steering).
If you want a recreational sports car that can entertain enthusiast drivers on both street and track, has practical packaging, rewards the acquisition of skill and excels at braking and accelerating (where payoffs are highest), then sling the engine down low just behind the rear axle.
Each of these is, in fact, the very best location for its intended purpose. The question is: what do you want?
You can't debunk it. The best spot for the engine is in the middle. Some key facts:
1. Last 911 to win Le Mans was the GT1 - a mid-engine 911. In 1998.
2. Porsche is moving towards a mid-engine 911 RSR for racing.
3. All LMP1 cars are mid-engine.
4. All F1 cars are mid-engine.
5. Why do you think that Porsche's hyper cars are all mid-engine (i.e. Carrera GT and 918)
Haaaahh.
The air cooled versions needed no coolant lines or upfront radiators. Rear engine also meant no driveshaft. Efficient and light.
I would assume one aspect of the 911’s less-is-more black magic would be a result of less drivetrain loss (on RWD cars, at least) as the power doesn’t have to transfer all the way across the car.
Middle is better and Porsche recognized it when they tried to kill the 911 in the late 70's until the world revolted. The point is the 911 is just a cool car! Porsche
has engineered most of the snap oversteer out of it and it is still one of the coolest looking cars ever. There is NO other car that you can Tell that THAT is a "insert car model here" from
the beginning to the newest model like you can a 911. Yes its the fastest car out of the corner. Look even the new 911 RSRs are mid engine. They just swapped the tranny and the engine
placements. They had to to get the rear diffusers under the car. Just enjoy the best looking sports car ever.
I generally agree but have a few nitpicks:
While the improved balance is definitely a nice benefit, the primary reason for moving to a mid-engined chassis is to make room for the massive rear diffusers that other cars are using. Aero is king on the track and the packaging constraints were making the 911s uncompetitive.
They currently are, but as recently as 2015 Nissan's GTR-LM Nismo LMP1 program used a front engine design: https://en.wikipedia.org/wiki/Nissan_GT-R_LM_Nismo
F1 is a constructor series with regulations. If the regulations required all cars to be rear engined next year they'd all be rear engined. That's like arguing that they all decided to go with hybrid V6 power because of the performance.
I don't think anyone is suggesting that rear engine layouts are dynamically superior to mid engined layouts. Mid engine allows for a better polar moment of inertia, but that isn't everything. At the very least, the traction and braking benefits that come from having the engine in the rear give the 911 its unique character. There are plenty of mid engined cars out there but the 911 (and technically the Smart car, I suppose) is the only game in town if you want this experience.
Ferrari 488GTB - 41.5 front 58.5 rear
Porsche 991.1 GT3 - 39.3 front 60.7 rear plus RAS......
RSR move, in large part, was for rear diffuser
All mid-rear, rear-mid cars need a thoughtful approach to weight transfer, front to back and side to side - underestimate this and they will bite
Hey Bemo, while braking dynamics are an advantage with rear engine cars, it's kind of for the reverse reason actually. With a larger % of weight in the rear, there is less weight transfer to the front wheels compared to a front engine car. This allows for more efficient and durable braking since there is less load on the front brakes. Think of your test drive around the 'Ring in the E92. When braking hard, so much weight is transferred to the front wheels causing the brakes to work extra hard. Also, the rear will lift a little more which can cause it to wiggle some whereas the 911 will be more planted. So yes, while the amount of weight transfer under braking in the 911 is a good thing, it's because there is less of if so more weight stays in the rear and all four tires are more involved during braking instead of just the front tires.
Compared with an E92, the 911's center of gravity height is probably an inch or two lower and that does reduce weight transfer, increasing this benefit even more.
Actually, "where" the engine sits is a very simplistic way of characterizing vehicle dynamics.
In addition to the engine, other components (transaxle or transmission, differentials and axles, fuel, etc.) and even the driver, have significant mass. The amounts of mass as well as placements, plus the rest of the car, determines the location of center of mass/gravity. The location of the wheels, front and rear, then determines the static front to rear mass (weight) balance. The distribution of mass relative to the CG determines the polar moment of inertia, the tendency of the car to rotate or spin.
All of this, plus the suspension design (spring stiffness, roll stiffness, damping, computer controlled components) and tires, then determines dynamics such as weight transfer and potential traction at each wheel.
So, a car with a certain engine location, or with a stated static front to rear weight balance cannot claim to be "better". The total integrated dynamic behavior is what matters, and wins races or makes a car fun to drive.
(If you want to really geek out, dig up Carroll Smith's old books.)
Also if any you out there are thinking that changing the oil in your 991 is complicated just look up what is involved with an oil change for a 993 or 993tt. On a scale of 1 to 10 an oil change is rated a 6.
Changing the oil in a 991 is trivial, but the way the lubrication system is designed, with the "internal dry sump" you still leave 4-5 quarts of old oil in the engine.
Received 5,388 Likes
Then why isn't Porsche dominating their class in the GT race series at places like La Mans and the IMSA races in the USA?
