Grill screens (radiator protection)
As I related many times, I dealt with Zunsport because I am a mechanical idiot but some people address me as "doctor". I installed the grills on my 2015 991 GTS and one fell off during the first week. Mr. Langston immediately supplied a substitute that has adhered since my mechanical epiphany.
You sure? Do you have a .2 w/ center grill?
When I visited their website, I was not able to select a center screen for 991.2.
Although, I only tried once. Either not possible, or backordered at the time. IDK.
Additionally, every pic I've seen here of a .2 w/ Rennline grill kit did not have a center screen.
Not for the 991.2 because they have active air flaps that supposedly close to reduce drag and improve fuel economy under lighter load.
I actually just had mine done on a 991.2 GTS bumper. I went with Rennline and only did the outer air ducts. I left the middle scoops exposed, which I think makes it looks more OEM (991.2 GT3 like). Also the transition from center plastic insert to exposed scope to mesh grill looks less abrupt IMO.
Another benefit is I can still reach in through the exposed scoop to clean stuff that will collect in front of the radiators.
I'm looking for screens for a 991.2 Targa GTS and prefer not having to remove the bumper... but the Zunsport site says they don'y have anything for that configuration?? How did you did yours? I just want to do the outer grills.
Thanks!
Thanks!
I would imagine it's the same as my 991.2 C2 GTS.
Thank you DBH! I ordered the outer set you have and they will be here on Thursday (that is FAST) The only remaining concern is whether PDK or sensors create any difficulty as I saw those issues mentioned on their website. In any case... jumping in with both feet.
Are you aware of any install videos for the GTS bumper?
Thanks again,
r
Thanks again,
r
Thanks again,
r
Thanks again,
r
PDK has nothing to do with grill install. The only sensors in the area that I'm aware of are on the black plastic trim piece on the outside of the intake (small circle).
There is an install video on the Zunsport website. Basically, place the grill into the outer part of the intake first then maneuver into place toward the center. Once in place, use a screwdriver to secure the clips behind the molding on the car - done. It took me longer to unpack the parts then to install them!
I have a brand new grill protection set from Zunsport for the 991.1 GTS including the center with parking sensors still unopened in the box for sale in the Marketplace if anyone's interested.
