Homelink worked without having to put garage opener into program mode
I picked up a 991.1 yesterday and I was programming my remote this morning. I noticed that it was immediately able to open and close my garage door right after learning the code from a garage remote. Usually you'd have to hit a button on the opener but today I didn't. Did Porsche put something fancy in the homelink? My garage opener is one of the newer Chamberlains with the back up battery so it does have rolling codes. Anyone else seen this?
Not quite sure what you mean. I used my clicker to program the home link built into the vehicle. Usually, one more step after that is required for the homelink to function properly with the garage opener in that you'd have to put the home unit into programming mode to "acknowledge" the homelink--typically by hitting a learn button on your opener. I didn't have to in this case and worked without that last step. I found it odd so was wondering if anyone else experienced this.
Hmm... I just programmed a Chamberlain on my 991.2 and had to do the extra step with the button push on the opener. It's curious that you have a newer unit with rolling codes and didn't have to do the extra step.
My experience suggests that Homelink has almost a random record of working, at least according to official procedure.
Any any success for me has been temporary (cross fingers).
Rocky Mountain High
If the remote that you used to program the Homelink system in your car was already registered with the opener, then this is possible.
I know more about this than I ever wanted to know. I’m on our HOA board and I’m responsible for programming our neighborhood gate, which is operated by a late model LiftMaster/Chamberlain unit.
I remember few years ago when I bought my first 991, the salesperson told me that it is preferable to not save my home address in the GPS, particularly if I leave my remote control in the car. I guess it applies even more if you have this homelink feature.
I dont feel comfortable with this option because I feel like anyone who steals my car also has a key to my home, so I never take this option..
I found with my '14 2S that the homelink instructions in the owner's manual were worthless to get it to work with my Genie. I went to the homelink web site, followed the instructions there and had it programmed on the first try in about 5 minutes.
Pete
Pete
Received 5,392 Likes
Very true.
Basically you (for rolling code opener):
1) Clear the existig codes by holding the outer two buttons for about 60-90 seconds.
2) Hold button you want to program until blinks rapidly.
3) Teach car by holding remote by front bumper and fog light till fog lights blink.
4) Press "learn" button on head unit.
5) Keep pressing programed car button until door moves.
6) You need to do steps 2-5 within about 90 seconds.
7) Done.
8) Don't park car under the door during the above.
