991.1 manual top speed each gear and downshifting question?
I posted before about heel toe downshifting into 1st and a lot of people suggested not doing it.
The other day I was going around 20 mph in 2nd gear and needed to pass someone and with the tall ratios the car just doesn't have much oomph (sorry for the technical jargon). What exactly would the problem be in downshifting to 1st?
It also got me wondering about the top speed in each gear for a 991.1 C4S. I found the gear rations here, but couldn't find the answer.
http://press.porsche.com/vehicles/20...ifications.pdf
GT3FZS (02-27-2020)
Considering that 2nd gear gets you to over 80 mph if I try that in the other gears I may discover the 80 to jail time instead ...
carrera manual
outside diameter: 682mm (26.9 inch)
outside circumference: 2142mm
gear 1 rpm 1000 travel per second: 2.7 m/s 9.6 km/h 6.0 mph
gear 2 rpm 1000 travel per second: 4.5 m/s 16.3 km/h 10.2 mph
gear 3 rpm 1000 travel per second: 6.7 m/s 24.1 km/h 15.1 mph
gear 4 rpm 1000 travel per second: 8.0 m/s 28.8 km/h 18.0 mph
gear 5 rpm 1000 travel per second: 9.6 m/s 34.6 km/h 21.6 mph
gear 6 rpm 1000 travel per second: 11.8 m/s 42.5 km/h 26.5 mph
gear 7 rpm 1000 travel per second: 14.6 m/s 52.6 km/h 32.9 mph
gear 1 rpm 7800 travel per second: 20.7 m/s 74.6 km/h 46.6 mph
gear 2 rpm 7800 travel per second: 35.4 m/s 127.3 km/h 79.6 mph
gear 3 rpm 7800 travel per second: 52.2 m/s 188.1 km/h 117.6 mph
gear 4 rpm 7800 travel per second: 62.3 m/s 224.3 km/h 140.2 mph
gear 5 rpm 7800 travel per second: 75.0 m/s 269.9 km/h 168.7 mph
gear 6 rpm 7800 travel per second: 92.0 m/s 331.3 km/h 207.1 mph
gear 7 rpm 7800 travel per second: 114.1 m/s 410.6 km/h 256.6 mph
carrera s manual
outside diameter: 685mm (27.0 inch)
outside circumference: 2151mm
gear 2 rpm 1000 travel per second: 4.6 m/s 16.4 km/h 10.2 mph
gear 3 rpm 1000 travel per second: 6.7 m/s 24.2 km/h 15.1 mph
gear 4 rpm 1000 travel per second: 8.0 m/s 28.9 km/h 18.0 mph
gear 5 rpm 1000 travel per second: 9.7 m/s 34.8 km/h 21.7 mph
gear 6 rpm 1000 travel per second: 11.8 m/s 42.7 km/h 26.7 mph
gear 7 rpm 1000 travel per second: 14.7 m/s 52.9 km/h 33.0 mph
gear 1 rpm 7800 travel per second: 20.8 m/s 74.9 km/h 46.8 mph
gear 2 rpm 7800 travel per second: 35.5 m/s 127.8 km/h 79.9 mph
gear 3 rpm 7800 travel per second: 52.5 m/s 188.9 km/h 118.1 mph
gear 4 rpm 7800 travel per second: 62.6 m/s 225.2 km/h 140.8 mph
gear 5 rpm 7800 travel per second: 75.3 m/s 271.1 km/h 169.4 mph
gear 6 rpm 7800 travel per second: 92.4 m/s 332.7 km/h 207.9 mph
gear 7 rpm 7800 travel per second: 114.5 m/s 412.4 km/h 257.7 mph
carrera pdk
gear 3 rpm 1000 travel per second: 6.3 m/s 22.7 km/h 14.2 mph
gear 5 rpm 1000 travel per second: 10.4 m/s 37.4 km/h 23.4 mph
gear 7 rpm 1000 travel per second: 16.7 m/s 60.3 km/h 37.7 mph
gear 3 rpm 7800 travel per second: 49.1 m/s 176.7 km/h 110.4 mph
gear 5 rpm 7800 travel per second: 81.0 m/s 291.5 km/h 182.2 mph
gear 7 rpm 7800 travel per second: 130.6 m/s 470.2 km/h 293.9 mph
carrera s pdk
gear 5 rpm 1000 travel per second: 10.4 m/s 37.5 km/h 23.5 mph
gear 7 rpm 1000 travel per second: 16.8 m/s 60.5 km/h 37.8 mph
gear 3 rpm 7800 travel per second: 49.3 m/s 177.4 km/h 110.9 mph
gear 5 rpm 7800 travel per second: 81.3 m/s 292.8 km/h 183.0 mph
gear 7 rpm 7800 travel per second: 131.2 m/s 472.2 km/h 295.1 mph
carrera s manual
carrera pdk
carrera s pdk
keep in mind 7 is OD, so the numbers for 7th are whacky
6th is a running gear, you can tell by the ratios. Or better yet look at Kolala's post, the speed difference per gear at top speed is roughly 30 mph, until you get to 7th where the difference jumps to 80 mph - that's the OD.
If you ever get to a track with a long enough straight you can tell 6th is a running gear because it has quite a bit of pull when you make the upshift. The back straight at VIR is a prime example
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
GT3FZS (02-27-2020)
