Didn’t pass CA smog. 2015 GTS little help
Old Nov 4, 2017 | 01:55 AM
See U n RearView's Avatar
See U n RearView
Talking Update...
So, all smells are gone and all I smell is the Alcantara, and leather...
I used this>
Ozone Ozone
< it took a few days for the Ozone to disappear, but it really worked wonders.
I, like many here, tried driving to get the monitor ready, but after 1 day I took it to a Local Dealer and met with a Really nice Service manager. He explained that some V V T Monitors, "pop" quickly and others don't.
One guy had a GT3 and it took him a week . Fortunately for me, it only took my 2015 GTS Cab an hour to fall in line. Then to add the proverbial Cherry on top, he did the SMOG Test, Passed the GTS faster than you can say, "Bob's your uncle," and submitted it electronically to DMV.
Will take to DMV for Vin Verification as is needed for vehicles that come from out-of-state.
So, he also did a complimentary inspection, and the GTS has a Great Bill of health. Now, I can concentrate on my clear side markers, and joining the local PCA...
File Type: jpg
File Type: jpg
Old Nov 4, 2017 | 09:51 AM
seapar's Avatar
seapar
Glad to hear this buddy. Brakes, tire wear all acceptable ? Enjoy it now. We had brief snow (didn’t stick) in Seattle but mid 30s. Canadian cold air intrusion. :-)
Old Jan 22, 2021 | 11:18 AM
imagerep's Avatar
imagerep
Originally Posted by -Ryan-
I had a similar problem in my 2015 GTS. I couldn't get the EGR monitor to reset. Drove it all kinds of different ways on long stretches of empty road. Took it back to the smog place multiple times and it still wouldn't reset. Finally bought a OBDII monitor so I wouldn't have to keep going to the smog place. Kept driving and still never reset. Took it to Porsche and within an hour they had it reset. Took it back to the smog place and it passed. Infuriating situation.
I am currently in this same situation. Just bought 2016 991,1 GTS out of Louisiana, shipped to CA, When it arrived, engine barely turned over due to low battery, now fully charged. Took it for smog as I need to get it CA Registered, FAILED. Smog place told me to drive it awhile as "VVT not ready". Been several days diving, now well over 200 added miles, driving roads & freeways. Still not ready for smog! I will try to get it into a dealer today as you did and see what they can do. I'm just hoping at this point it's a simple fix and there are no underlying other issues I'm unaware of....
Old Jan 22, 2021 | 03:37 PM
barncobob's Avatar
barncobob
i believe the federal law on smog is for manufacturer to guarantee it for 8 years,,unless of course someone tinkered with some mods....i never buy a car that is not currently registered here in CA.
Old Jan 22, 2021 | 07:11 PM
Southbranch's Avatar
Southbranch
Here's the warranty table from my 2016 GTS's warranty booklet:
Old Jan 22, 2021 | 07:23 PM
Brian E's Avatar
Brian E
Your low /dead battery is more than likely the culprit. It probably triggered a systems not ready when they smoged it. Give below a try. If you have a hand held code reader you should be able to check to see if it worked before going back.Generic Drive Cycle Instructions:
1) The generic drive cycle begins with a cold start. Coolant temperatures must be below 122 °F and the difference between coolant and air temperatures read by the sensors must be within 11 degrees.
2) The ignition key must not be left on prior to the cold start – otherwise the heated oxygen sensor may not run.
3) As soon as the engine starts, idle the engine in drive for 2-1/2 minutes with the air conditioning and the rear defrost on.
4) Turn the air conditioning and the rear defrost off and accelerate to 55 mph under moderate and constant acceleration. Hold at a steady 55 mph for at least 3 minutes.
5) Decelerate to 20 mph without braking or depressing the clutch.
6) Accelerate back to 55 to 60 mph. Hold for 5 minutes. Decelerate to a stop without braking.
Old Jan 22, 2021 | 07:30 PM
imagerep's Avatar
imagerep
Thanks. I printed this out in case I need it. This 2016 GTS was originally sold in CA, then the 2nd owner had it shipped to LA, and now it's back in CA with me, the 3rd owner. That said, being that that it was originally sold in CA, your 7 Yr chart should still apply.
Old Jan 22, 2021 | 07:35 PM
imagerep's Avatar
imagerep
Sure would be easy to do if I lived on a closed track course! Crazy, no? After step 3, it would take me 4 mi in stop/go to get to a freeway. Would that screw up the sequence?
Old Jan 22, 2021 | 08:12 PM
Brian E's Avatar
Brian E
I have a buddy who lived in a state that smog checked and he had the same issue as you. He bought the car out of state and by the time he got it delivered the battery was dead. He said the dealer gave him this procedure, he followed it and it worked. He sent it to me back in 2014 and I saved it. Called him tonight to see if he remembered how closely he followed it and he said he couldn't remember, but did confirm it worked for him. He said he thought he did it a couple times. He confirmed that his hand held code reader showed systems ready afterward. Hope this helps you.
Old Jan 22, 2021 | 08:32 PM
imagerep's Avatar
imagerep
Thanks! Was told today to drive it with AC off and don't use cruise control, Hell, I didn't even put in in Sport mode. Cold engine idle for 3.5 min, then 20-30 mph for ~ 3.5 min., then got on fwy and drove 50-60 for about 10 mi, all of this never going over 3k rpm. Not as easy as it sounds. While on fwy in the far right slow lane at 55 mph WITH MY FLASHERS ON, several people honked at me as the drove around. Really cracked me up how stupid some drivers are. No compassion having flashers on in the slow lane. Then nerve of me making them move over a lane. LOL.
Tomorrow early AM I will use your procedure, then head to Smog for engine eval.
Last night I did order a OBDII Reader off Amazon (Autel AL329) but that unfortunately won't arrive for days.... Same unit my Smog place uses.
Praying this will do it tomorrow but not holding my breath. Here I didn't want to put much mileage on my just received GTS and all I've been doing in putting unnecessary miles on it to get this crap to clear! My friends give me no sympathy on that comment at yesterday as I drove along Pacific Coast Hwy in Malibu in 70 deg weather.
Old Jan 26, 2021 | 12:15 AM
imagerep's Avatar
imagerep
I want to give my final post on this subject for all to read. Yesterday I used the earlier advice from Brian E. Short story- did nothing to set my last pending (EGR) monitor on my handheld OBDII reader. Now I was at 340 miles and still can't smog the car. This morning I took it to my Porsche Dealer. My service Mgr laughed when I told him about this thread and all the miles, effort and agony I put into this. He said I should had called him and come in days earlier. He took the car, had it with a tech for less than an hour (they also did the most recent 'campaign recall'), and gave me a bill for $225 ... and all ready to get it smog'd.
We all know this is all such BS being that the Porsche techs have the simple formula how to set the monitors quickly. Did I say they didn't even drive the car?!! I noticed when I got in, my headlight switch was set to OFF (I always leave on Auto). My guess that is just one setting with a host of others, then rev to an exact rpm for 'x' number of minutes and seconds, etc.
My advice to any of you with this issue, pay the crazy rip off price with the dealer and be done with it! Save the gas expense and extra needless mileage on the car.
Old Jan 26, 2021 | 01:55 PM
Southbranch
So, did the dealer explain why the cost of this service visit was not covered by the factory emissions warranty?
Old Jan 26, 2021 | 03:50 PM
imagerep's Avatar
imagerep
Because it was not an emissions issue due to any fault of the car. If I continued to drive the car it would have eventually tripped but who knows when? The charge was based on minimum hourly rate at this dealership.
Old Jan 26, 2021 | 04:27 PM
Guards_Red_991's Avatar
Guards_Red_991
Just move out of California... It will only get worse.
Old Jan 26, 2021 | 04:51 PM
imagerep's Avatar
imagerep
I actually had a neg comment about CA in my post but edited it out before posting. No bargains here in CA. Yesterday I registered by 'new' 2016 911 GTS with the CA DMV. It was nearly $1000.00 for the 1st year. That's not counting the over $9,100.00 pd in sales tax. Yesterday was not a happy day.
