PSE Questions :: 991.1 C4S :: No Discernible Change
#31
Sadly no. I kept the car only a week and ended up swapping for an audi TTrs but that car is also gone. I’ve owned 69 cars in 25 years so I may have a problem hahaha. Regretfully this means I can offer no help here. Sorry.
#32
Ive had this issue with my .1 C4S for some time now and I'm so over it at this point. The car now has a SOUL exhaust on it and everything is hooked up correctly but the valves clearly aren't opening. I tested the closed valve technique and the car sounds amazing with the valves forced open but it eventually throws the cooling code.
My aggravating adventure so far:
1. One INDY shop found a busted COV and replaced it but the PSE still doesn't operate the valves $400
2. Just got car back from the Dealer who had my car for 3 weeks and did over 5hrs of "diagnostics" on it and could find nothing wrong with it. WTH ?? $500 I'm tempted to contact PCNA to complain as this is a small Porsche dealership and I honestly feel that they ARE NOT skilled with 911's...(Only had 1 911 at the dealership)
3. At this point I have no clue what do to next as its been to both Porsche authorized mechanics with no luck on why the exhaust flaps wont open on the PSE..
So at this point ive spent almost $1000 just to the exhaust valves to open correctly...
John from SOUL has been great !!! he sold me a Valve controller kit so this is my last hope for the PSE to open correctly...I will be installing next week
#33
Received 3,455 Likes
Slightly off topic but is there an easy way to have the Sport Exhaust valves always open, such as a fuse?
#34
#36
#38
Hi, ive tried this on my exhaust valves as well since the valves don't wanna open anyway, and after a awhile it throws the Cooling Code message...Is there a way around that ??
#39
Bob, I ran no valves on stock and 2 aftermarket exhausts. 1. It sounds better, 2. You make a little more power down low, especially with the high flow cats
On the .2 theres one valve on each side of the center muffler. Get the car on ramps and get under there with a flashlight. The vacuum lines are steel braided and clamped on Very tightly. Heres some tips. You basically want zero vacuum leak in the disconnected hoses
1. Get some 4mm high temp silicon vacuum hose caps (female) for the male connections
2. For the hoses...You will need double sided male plug connection to plug the steel braided lines, but you may need to jam them in with some force into the steel lines if you dont remove the clamp ring. Then on the remaining side of the double male connector place a female cap
3. Be very careful not to tug on the hoses because at the proximal end (nearest to the engine) they are connected to long flimsy metal pipes that are aluminum and rather flexible... and if you crack them it will leak vacuum. This will throw a code and you will have a bad day
4.for the valves... Plug the valve actuator nipple with another female cap so dirt doesnt get into the vacuum chamber
5. Enjoy
honestly its so easy I bet your dealer would do it for free. They have all the plugs also
cheers
5. Enjoy
cheers
#42
