Brakes and rotors
Brakes and rotors
I've got a '14 C4S with about 17k miles on it. My rear brakes need replacing. I used them up at my last DE weekend.
I was looking at my options for aftermarket pads. I drive my car year round, and I do about 2-3 DE weekends a year. I'd rather not put on track pads each time.
Given how I use the car, I'm leaning towards either Brembo TS20 pads or Endless MX72 pads. Has anyone used these, and if so, have you been happy with them? Am I going to get better performance and wear vs OEM? They cost about 2x vs OEM, so I'm trying to decide if they're a worthwhile upgrade.
One other thing, what's the consensus on replacing rotors every time the pads are replaced? The dealer says that is what is recommended, but I'm thinking if the rotors are within spec and aren't badly grooved or have a lip, then I should get more life out of them. Thoughts?
Thanks!
Thanks!
Check the rotor hats, there might be a marking that indicates the minimum thickness.
However, if you are tracking the car, you might as well replace it. Brakes and tires are very important.
Stick with OEM pads until you feel that they are not performing for you. You'll know.
You will then have to swap to race pads before a weekend or live with the annoying squeal and weak bite in the cold (depending on where you live). It's a rabbit hole and you are staring down it.
