991 up on jack stands
Old 09-08-2017 | 10:53 AM
friar93's Avatar
friar93
someone mentioned cracking the frunk open and leaving it. I know in my 993 theres a light that goes on and will drain the battery if its open(is there one i the 991?). you may want to disconnect the battery as well(assuming a trickle charger wont do you any good with power out)
Old 09-08-2017 | 10:56 AM
LexVan's Avatar
LexVan
Not necessary on the 991. The frunk light will turn off in about 12 minutes.
Old 09-08-2017 | 11:10 AM
LexVan's Avatar
LexVan
Sessionstu, if you can, please try to use a proper jack pad with center bolt.
Old 09-08-2017 | 11:32 AM
ace37's Avatar
ace37
Why not remove the battery altogether? It's no cure all but at least it would be a quick and easy way to prevent any electrical shorts from destroying the car.
Quick Reply: 991 up on jack stands
