Clicking noise after shutdown.
I have gotten used to the sounds my 2013 C2S makes for a few minutes after parking it. Sounds like relays opening or closing. However today I walked by the car about an hour or more after driving it and the same sounds were still coming from it. About every 30 seconds I would hear what I assume is a relay opening /closing from somewhere in the frunk area. Tried locking /unlocking no change, finally started the car and let it idle for a few minutes. That seemed to work and the noise stopped. Any ideas as to what is going on?
Checked the car again about an hour or so after last shutdown. It is doing it again. Sound seems to be coming from driver's side behind the dash, upper foot well?
Received 5,388 Likes
It's not normal. Be careful so you're not left stranded with a dead battery. Needs to be diagnosed.
Relays clicking every 7-10 seconds whith key out of ignition
Porsche 991 s 2013. With key out of ignition, locked or unlocked, doors open or closed, the DME and fuel pump relays energise every 7 - 10 seconds. Left unattended the battery will go flat in no time, so dissconecting the battery for now . As soon as the key goes into the ignition it all stops. The car has no fault codes, it starts and drives with no isssues. If i drive the car, stop, get out and leave it, it takes about 30 minutes to start the fault process again. I see an old similar thread with no conclusion.Any ideas?
