Turbo S - Center Grill or Not??
#61
For all the questions pertaining to sensors, I have not encountered any problems. This car is new to me so I may not know all the details.
Based on what I can see on my car, I have the center ACC. The center grill is two piece and is pre-sized to fit quite nicely around the ACC eye.
As for sensors, there some on the bumper and one on each side of the car embedded in the black plastic trim. The Zensport side grills are actually three separate pieces per side. The center insert has a rounded cut away to enables the grill to fit well around the sensor housing (see first and third pics).
#62
Here is the pic from the other thread of a GTS that has sensors and the correct made to fit up to, but not over - guards for comparison.
#63
Shaggy, I don’t know what to tell you. I used the search feature on the website to find these. The center inserts have circular cut outs at their ends where they go around the sensors.
Thus far, they seem to be working fine with the sensors. I will keep an eye on this though.
Here is the link to the parts I ordered.https://www.zunsport.com/en/porsche-...o%20s&limit=75
Here is the link to the set without sensors. https://www.zunsport.com/en/porsche-...he%20turbo%20s
Since Zunsport went to the trouble of listing grill sets that specifically state “without sensors”, I just assumed the ones I ordered would be for cars with sensors!
#64
Actually now I'm on my laptop I see your sensor off to the side, its not covered, my bad. It appears the 'S' intakes are a little different than the non S. Yours appear to be correct, my apologies!
#66
Greg, I have parking sensors and no ACC on my 2014 911.1 tts . From your pictures and what you said, even I ordered the “wrong” set according to Peter at Zunsports, I think it works. My central piece is one piece and should have no problem as there are no sensors in the middle. For the sides, since the sensors are on the side inside the bumper, I think I am good. Do you think I miss anything? I will try it this weekend.
#67
Hello Peter
I ordered the grill set for my Porsche 991.1 Turbo S. It has parking sensors and ACC. I’ve been told by some that your grill set ZPR 60911B (which I ordered) is not compatible with cars equipped with parking sensors although they seem to fit quite well. Did I order the wrong grills?
Thanks in advance
Greg
Hello Greg.
If your car as stated " Porsche 991.1 Turbo S. It has parking sensors and ACC " product code ZPR 60911B is correct.
They maybe referencing the Porsche 991.1 Turbo (none S ) which is a different product code .
Kind Regards
Peter Langston
Zunsport
