Cobb Tuning Porsche 991 Turbo Accessport ECU Tune NOW IN STOCK at BBi Autosport - Rennlist - Porsche Discussion Forums
Go Back  Rennlist - Porsche Discussion Forums > Turbo Technical Discussion Areas > 991 Turbo
Reload this Page >
991 Turbo Turbo and Turbo S
Old 09-16-2015, 11:22 PM
BBiAutosport
Basic Sponsor
BBiAutosport's Avatar
Default Cobb Tuning Porsche 991 Turbo Accessport ECU Tune NOW IN STOCK at BBi Autosport
Cobb Tuning Porsche 991 Turbo Accessport V3 ECU Tune
Now in Stock & Ready to Ship from BBi Autosport
Porsche 991 Turbo S 2015 Pikes Peak Time Attack 2 Class Winner
No performance upgrade is complete without a tune to reliably extract as much power as possible while maintaining excellent driveability and consistent results. The Accessport for the 2014-2015 Porsche 911 Turbo and Turbo S is the ONLY handheld flash option. Being the world's best selling and most flexible ECU upgrade solution, the Accessport V3 comes with Stage 1 and Stage 2 Off The Shelf maps as well as complete custom tuning capabilities for any modification level. BBi Autosport is not only proud to be an Authorized Dealer and Certified Porsche ProTuner for COBB Tuning but also a dedicated technical partner. Striving to be at the forefront of Porsche ECU tuning technology, Cobb Tuning brings a wealth of knowledge with ECU tuning since 1999 and BBi Autosport has been instrumental with helping Cobb Tuning's development for all applications since its first foray into the Porsche market in 2014.
It provides Off-The-Shelf (OTS) maps for Porsches that are stock or has minor bolt-on upgrades. These OTS calibrations unlock power hidden within the vehicle by replacing conservative factory settings with more aggressive calibrations. For Porsche vehicles that are modified beyond the scope of the OTS maps, we also offer individualized dyno and remote Pro Tuning service that are unique to each vehicle. Capable of handling well over 1300 WHP, Pro Tuning is necessary for clients that have extensively modified their vehicles with parts that are not supported by the OTS maps, such as upgraded turbochargers, fuel system, and engine internals. The Accessport is the easiest modification you’ll ever install. Simply plug the cable into the OBD port in your vehicle, connect the cable to the Accessport, and then select install from the main menu. You will then be prompted to select from a list of Off The Shelf maps. Select your map and about 5 minutes later, your Porsche is ready to be unleashed! After lots of testing on development cars throughout the country, and more data gathering and analysis on a 991 Pikes Peak Hillclimb Racecar, we’re happy to announce the final product is now available
Power Gains:
Stage 1
Pictured below is the initial Stock Baseline pull on 91 octane fuel along with a Stage 1 OTS map using 93 octane fuel. A Stage 1 map would be used on an otherwise completely stock vehicle. Power under the curve is significantly increased throughout the low and mid range. Maximum gains of around 60whp are seen between 3000-4000 RPM. Most impressive is the increase in low-end torque, with gains of over 100 ft/lbs!
Stage 2
A Stage 2 map is calibrated to be used on a car with our BBi Barcode exhaust. As is evident with the power gains, the motor is able to flow a significantly greater amount of air with the freer flowing exhaust. With gains of 120 ft/lbs down low and nearly 100 hp at peak, the cars become a whole new animal. We are able to be a touch more aggressive utilizing 100 octane fuel, this will be a great option for customers interested in tracking their car where detonation resistance is key.
Features
Simple Installation:
Everything is included for the simple installation you can do in your driveway! Intuitive on-screen instructions identify your exact vehicle, saves stock vehicle data, and displays available OTS maps.
Change Maps:
Store up to 100 maps from our OTS map database or from your favorite COBB tuner and quickly switch between them for any need.
Data Logging:
Record multiple data channels simultaneously for in-depth evaluation of engine performance. Stores up to 1 hour of continuous data.
Gauges:
Use your Accessport as a gauge to monitor boost or any other live information, directly from the ECU.
Performance Measuring:
Welcome to your own performance evaluation suite! Measure 0-60 mph time, 60 foot and ¼ mile ET’s. and Trap Speed.
Trouble Codes:
Read engine trouble codes to diagnose issues. Clear them when resolved. Prevent expensive trips to the dealership.
Full Uninstall:
Using the Uninstall option will completely remove our programming from the car’s ECU. It is then able to be re-installed after a dealer visit or on another vehicle.
Additional Images
About BBi Autosport
Based in Southern California, we are a Porsche tuner and parts manufacturer. BBi Autosport was founded in the summer of 2005 with the mission of bringing artistry and craft to the Porsche tuning industry. We are committed to producing proven performance upgrades that are manufactured to the highest quality standards. With our new bigger facility, new staff and new product catalog this year, we are a one-stop shop and excited to offer everything from race car builds to scheduled factory maintenance.
With over 30 years of combined motorsport history, BBi’s operation is truly unique. Racing traditions run deep here at BBi Autosport. As the company's founder and technical director, Betim Berisha has worked in Racing for many years at prestigious events like the 24 Hours of Lemans and 24 Hours of Daytona. First for Fordhal Motorsport working on their GT3RS and Saleen S7 in ALMS and Grand Am series, Alex Job Racing on their ALMS GT3RSR, J3 Racing working on their GT3RSR and then Porsche Motorsports North America as their dyno tech an supporting Porsche teams at ALMS, Grand Am, Speed World Challenge events. Sharing the same passions, most of BBi's support and shop staff have also previously worked for other motorsport programs. Being a one-stop shop, BBi Autosport is equipped to offer everything from hand-built hard goods to championship-winning GT3 Cup Cars.
For up to date information of current shop activities, projects, and product releases, please follow us on our Facebook and Instagram accounts:
https://www.instagram.com/bbiautosport
https://www.facebook.com/BBIAutosport
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: [email protected] Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
BBiAutosport is online now
Old 09-18-2015, 03:21 PM
BBiAutosport
Basic Sponsor
Old 09-21-2015, 07:29 AM
BBiAutosport
Basic Sponsor
We have them in stock and ready to ship from BBi Autosport.com
- [email protected]
Old 09-24-2015, 02:39 PM
BBiAutosport
Basic Sponsor
Porsche 991 Turbo S in for Cobb Accessport Protune
- [email protected]
Quick Reply: Cobb Tuning Porsche 991 Turbo Accessport ECU Tune NOW IN STOCK at BBi Autosport
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
