"Fault of allwheel drive system"
2 Attachment(s)
Hey guys,
Posting for a friend. His 991 TT-S threw this error today. Car won't go into Sport mode. Any ideas? I did a search both here on RL and on Google, but can't seem to find much. Also, he can't take it to the dealer because the car is a parallel import and Porsche in this country has a policy against servicing cars not purchased thru them. (I know, that's a controversial policy, but it is what it is and please take it as a given). If something needed to be replaced, he would need to import the parts himself and have an independent garage do the install. So the first step is diagnosis... Attachment 1358832 Attachment 1358833 thanks in advance! |
Ouch ... The first thing I do after starting is sport mode.
This is the precise reason why there is a campaign to change the AWD control unit. An error code can appear showing a problem within the AWD when there actually isn't. It's to do with a faulty sensor in the actual control unit. Mine was done a month back now but did not manifest the problem when it was in my car thankfully. Campaign is WE89 if that helps. If the dealers where you are will not help then you will need to purchase the unit yourself.
Has he already disconnected/reconnected the battery to see if it was an electronic glitch that can be 'cleared'?
^ It is worth a try and hopefully it will work as a temporary measure.
A repair shop should be able to buy the parts from the dealer if needed. Also, I'd try a different dealer. If it's agreed up front that it is not covered by warranty, most shops would take the money to work on it.
Originally Posted by Randyc151
(Post 12456913)
thanks for all the inputs though; i think my friend has enough info to go on. looks like he'll need to source the ECU from the middle east, which is where the car was originally sold. cheers! |
Originally Posted by hesperus
(Post 12459610)
Unfortunately there's no different dealer here, because technically there is only one importer into this country, and that importer owns all the dealerships. so yeah, as long as you didn't buy your car from them (i.e., it was a parallel import,) you're out of luck.
thanks for all the inputs though; i think my friend has enough info to go on. looks like he'll need to source the ECU from the middle east, which is where the car was originally sold. cheers! Throwing the "Fault of All-Wheel Drive" code could be connected to half a dozen items (or more). The problem is more likely in one of the modules rather than the ECU and therefore, without skilled diagnosis, changing-out the ECU is really just a shot in the dark. He is best off getting a Durametric first, reseting the codes, then troubleshooting before sourcing an ECU. When he's done with the DM, it can be either resold on eBay or kept around if he ever needs it again (like when he needs to reset his service light after an oil change.) |
Are you stoked, waiting for your TTS? I can tell you - it's worth the wait!! I love this car! All of my parts including the wheels are now in and getting installed next week. Can't wait!
Originally Posted by FBA
(Post 12459886)
(Post 12459610)
Originally Posted by worldattorney
(Post 12459752)
Originally Posted by speed21
(Post 12460053)
The faulty module is within the AWD control unit itself, hence why it has to be changed out. When mine was changed out I enquired the specific details on the fault itself (which took time for the dealer to get the info from HQ) and OP has the exact symptoms. So I can safely assure changing the AWD control unit is no shot in the dark. It is located in the front luggage compartment...
(Post 12460120)
OP said "ECU" which is the entire car's brain...the AWD control unit is a sub-system control module
In addition, it may not be the AWD control unit. It could be a single wheel sensor...or a plug that came off off, or a fuse, or a system temperature sensor, or at least 10 other things...We are diagnosing from a readout on the dashboard, not specific codes. Some fault codes (as defined by the vehicle engineers) only have to trigger once to put the car in a sort of 'limp' mode or limit certain functionality until repaired...others need to trigger a certain number of times over a give time period or number of drive cycles.
The proper procedure is to first pull the codes, then clear the codes, then conduct a 'guided-fault find' using a computer, then replace/repair whatever is listed in the first code that 'pops', then clear, then repeat until no more codes come up. It is very rare that a single code will ever come up by itself, that is why we always start with the first then fix then retest until all clear. (My background is expert witness preparation and strategy in criminal trials that involve automobiles. Besides building and modifying street and race cars as both a hobby and professional (a long time ago), I specialized in vehicle engine management systems, electrical systems and electronics) |
