Launch control didn't work?
I tried my second LC start today. My previous attempt worked perfectly. Today I was in Sport+ with the transmission in auto, at a complete stop, left foot brake and when I pressed the gas with my right foot, the Launch Control light didn't come on and the engine revved up slowly as if it were still in gear and it was torque braking. I tried again with the same conditions and got the same result. The only thing I can think of is that I didn't press the gas down past the kickdown button. Is the LC conditional on activating the kickdown?
Thanks,
Patrick
Thanks,
Patrick
Thanks,
Patrick
Thanks,
Patrick
Should come on after 5500 rpm no matter how ginger you are with the gas. However, it's no fun if the pedal isn't to the metal the entire time after you launch. Then you just hang on and watch the road and the occasional glance at the speedo to decide when you have had enough.
Small point for those who do LC, but the speedometer is a few mph behind the actual speed of the car so when it reads 57 it is more like 60 mph when executing LC. This from a PSDS instructor during the TTS LC sessions at Barber.
I believe it. If you floor it in any of the bottom three gears the digital speedo looks like a slot machine wheel.
