GMG vs. Techart Vs. H&R springs
Hey Speed,
I stuck with the 20's as I wanted to keep the original tyres. The rims are slightly wider so I can go larger later.
Haha, I live in Queensland, Australia.... I'm always doing country runs
My regular route home has several pronounced dips and bumps... which in the past on other vehicles I have had problems with and needed to slow down. Thankfully I have not had this issue with the Techart springs.
I've been modding cars for a few decades now, and you know that feeling after a mod when you have to weigh up the good and the bad to see if it was worth it... well honestly the Techarts have been all positive so far. No doubt for me personally it was a great decision with no regrets at all.
I had the Europipe exhaust fitted at the same time, and I have the same feelings with that....all good, and nothing to fault.
Cheers,
Scar
P.S. sorry about the size of the pic, didn't realise it would post that large
Cheers,
Scar
4flynlow (09-18-2019)
Hey Speed,
Cheers,
Scar
Cheers,
Scar
Did you GIAC it yet?
Hey Speed,
My car is a DD, would average about 15,000 Km's per year, so she's no garage queen
Must admit I have slowly pushed harder and harder in the areas we have some rather large dips, and nothing so far. Entire front is wrapped, and yes parts of the rear as well. I won't even drive a new car out of the dealership now before it's done.
Had my GIAC stage 2 done about 2 weeks ago..... just WOW!!
Still very much enjoying my 991TT, which is rare for me. I usually get bored by the 12 month mark and buy something new. Might hang on to this for another year and look at the market then.
Cheers,
Scar
Cheers,
Scar
Sounds good Scar. Did you have to pull the ecu - or send it to US for the flash? Any means to data log using Durametric cable? How does it run on the 98? Has the dealer looked it over, or given any thoughts? Sorry so many questions...
I am so close to trying out the Techarts. I need to find someone I trust to touch my car. I also would love to see some before and after side shots with stock wheels. It seems that most every picture out there is with upgraded and most importantly larger wheels.
Any real techy people know and can speak definitively that adding these springs do not mess with the Porsche active suspension?
I installed them last week on my 2016. The drop was more than 30 mm for some reason, and that was with higher profile tires overall. My front spoiler now has about 2.5" of clearance when deployed and it's pretty aggressive looking - but too close for comfort in some cases, so I roll it up more than I did before, out of caution.
That said, the ride comfort is about the same but its somewhat tighter around corners. There are no apparent issues with the PASM. PASM works with the shocks and is unaware of the springs, from what I was able to deduce. You may feel a bit more of a harsher ride than I do, because I went with higher sidewalls over stock and Michelin PSS instead of P Zero's, but it would be negligible IMO.
I posted on the other site under "My 2016 TTS with mods". Pics are there and you can clearly see the drop on Techarts.
I installed them last week on my 2016. The drop was more than 30 mm for some reason, and that was with higher profile tires overall. My front spoiler now has about 2.5" of clearance when deployed and it's pretty aggressive looking - but too close for comfort in some cases and I roll it up more than I did before, out of caution.
That said, the ride comfort is about the same but its somewhat tighter around corners. There are no apparent issues with the PASM. PASM works with the shocks and is unaware of the springs from what I was able to deduce. You may feel a bit more of a harsher ride than I do, because I went with higher sidewalls over stock and Michelin PSS instead of P Zero's, but it would be negligible IMO.
Good to hear about all the other stuff. I really want the exact ride with taking up a little of the wheel gap. Performance etc to stay the same is fine. It appears as that is exactly what Techart does.
It will look insane on stock wheels and rubber! I'm not a huge fan of lowering generally, but with the Techart's, it's a whole other story. They nailed the spring rate right on!
4flynlow (12-03-2019)
May explain why RoW springs are not different than US spec
You know that there is no need to change springs to lower your car. My body shop guy, Marnum collision in Marietta, ga adjusted the ride height of the suspension. I was always under the impression that springs were the answer and that is direction I took on previous cars, however always resulted in a compromised ride quality. They adjusted my turbo 1.1" with no sacrifice to original ride.
GMG progressive springs for me. Great ride on street or track. Perfect drop....not too much!
Premium Sponsor
Techart is our favorite here at TAG. Just enough drop without sacrificing ride quality. All of our customers who have opted for these have nothing but good things to say about them!
TAG MOTORSPORTS
866-793-5490 x1192
web: www.TAGMotorsports.com - email: sales@tagmotorsports.com
Authorized Dealer For: HRE, Vossen, TechArt, AWE, Bilstien, KW, Akrapovic, Capristo, Fabspseed, BBI, Vorsteiner, Milltek, 1016 Industries, BBS, Brembo, GMG, H&R, Pirelli, Michelin, Hankook & more.
TechArt & AWE Tuning's #1 Volume Dealer Nationwide
866-793-5490 x1192
4flynlow (12-04-2019)
