Benefit of PSP or Difference in the TTS suspension?
After driving in 4 straight mornings of freezing weather, I have noticed that that crazy " wheel hopping and knocking/thunking noise" when turning sharply is NOT present in my TTS. I always blamed the Pirellis in cold weather, but now I am wondering if power steering plus did away with it? Or something else with the turbo suspension.
At any rate I am happy to be rid of that crazy phenomenon.
Anyone else notice this?
Ha!
Fair question, though.
It has been high 20's/low 30's over night. My 2013 S definitely did the crazy wheel "thang" (so did the R8, which is why I blamed Pirellis) when i turned sharply out of the driveway so I noticed instantly the TTS doesn't.
Got it. Wondering if the 4 wheel steering has something to do with it. You might not be turning the fronts as hard as you think to get the car pointed where you want it to go. My 2013 S did it too.
I'm in WA. It was around 20F degress when I pulled out of the garage this morning and the temp gauge in the cockpit was reading 40 something (so cold but not sub zero where the tires had been sitting overnight). I got several big and loud skips...more than usual but it's colder than usual. I'm on OEM Pirellis and I have PSP although mind is a TT not a TTS; I think for this context the difference probably doesn't matter though.
Only cure I've found is to apply less steering lock.
I get it on my TTS, No PSP, Pirellis. It is more obvious when cold and reversing especially full lock but also present full lock going forwards slowly. Very weird feeling which I haven't experienced in any other car but assumed it was wide rear tyres coupled with the rear wheel steering.
Thinking about it now, I bet running at partial load/comfort pressures rather than full load/standard pressures might potentially [marginally??] reduce the symptom.
I've had my TTS for 1 week and this occured when it was very cold out. I thought something was very wrong - sort of freaked me out. I couldn't figure out what was going on. But, after straightening the wheel, all was well and I moved on. Anyway, car is mostly put away for the winter now (sadly).
happens to me in my 991S when at full lock, mostly noticed when backing out of a spot, and happens in summer or winter... Asked service about it, nothing wrong and fairly normal, just geometry and tire size when at full-lock...
