Help !! 911 turbo s oil drain plug location
I put the car up on my lift and found the drain plug easily.I put a Dimple Products magnetic drain plug in.I was told that there is only ONE oil drain plug on this car.Can someone clarify this? Thanks.
Is the Turbo a Dry sump? if not then you only have one. I will look this up.
Look in your manual. If the manual says Integrated DrySump then it has one.
If it says Dry Sump there will be two.
On page 29 of the NEW 2014 Turbo brochure, it says "The integrated dry-sump lubrication ensures reliable oil supply...
I believe you have ONE oil drain plug. When the turbo'd the new 9A1 motor they didnt add a real dry sump that the mezger motor had in the 997 Turbo. I guess Porsche feels this new 9A1 motor is strong enough to Turbo without a real dry sump.
