Build Comments/Suggestions
Putting down deposit on the TT, scheduled delivery 12/27.
This is my draft on the build, comments and suggestions please. Checking into deviating black carpet as well.
http://www.porsche-code.com/PEZ24T45
In your case however, not sure about it.
Don't forget that the Turbo S not only gives you 40 hp more but also a louder exhaust note in the upper rev range (sound symposer programmed differently), a higher rev limit (7200 rpm instead of 7000 rpm, which is noticeable during upshifts because rpm falls back just right for a perfect continued acceleration ), all those Turbo S logos (PCM, speedo, pneumatic front lip, etc.) and of course a higher torque figure which is noticeable even at lower speeds.
Just saying...
If you plan to tune your car using chip tuning, be aware that PTM is completely new, same goes to the rear axle steering. All systems are now connected, incl. PDK, the steering and everything else related to the engine, so messing around with this stuff may not only be ineffective but also dangerous at some point. Porsche made sure that upgrading the Turbo to Turbo S power by using OEM software won't be easy. Not only the ECU would need an upgrade...
Of course everything is possible (doable) but why risk it?! Also if you don't track race your car very often, the PCCB brake system is a blast to drive.
Otherwise, your option list is quite nice but paying over 3k for GT silver when you can get the new Rhodium Silver for free? Not so sure.
Thanks for input! As I am going to track the car at least 6-8x a year, I don't want the center lock wheels or the PCCBs, so from that respect the S options are a negative for me and I'd be paying more for things I don't want. That's also the reason I'm optioning PDCC for the TT, for better even tire wear from track use. Exhaust is def a negative, and it likely will be the only aftermarket mod I do, definitely won't be messing w/ the ECU or anything else w/ the exception of maybe alignment though I'm not sure if I'll mess w/ that given the PDCC and RWS.
As far as rhodium, it looks good but I'm not a fan of the bluish tinge, I like the GT silver's darker deeper look and how it blends w/ the red interior. I was also considering agate, but it's a bit too brownish for me, and my wife won't let me get white lol.
Great looking build! I would add the steering column casing in leather as well as the center console in leather. The glare is bad from the chrome in bright sunshine and the steering column looks cheap in plastic.
aJag, You can see a photo of a Cayman in Rhodium Silver next to a boxster in GT Silver in the new GT3 Section.I have a Panamera S in GT Silver and after seeing a Cayman in Rhodium, I prefer that to my GT Silver.The Blue Tint is really not evident to me and the color changes shade slightly in sunlight.Gorgeous!
I feel your pain in not being able to buy the Turbo S due to CL wheels and Ceramic brakes. I love Turbos but also spend time on the track and paying 10 times the price for rotors and pads vs Steel Rotors becomes prohibitive for tracking. On my 996TT, New Steel rotors, pads and a fluid change cost under $2,500.I priced the same parts with Ceramics at my Porsche dealer and it was $25,000!
Porsche badly needs a "Track Pack" Turbo ala the Nissan GT-R. Stiffer suspension, Turbo S HP with Steel rotors and 5 lug wheels. Beats me why they don't see this. So I've ordered a GT3 in Rhodium Silver.
ajag, This is the link: https://rennlist.com/forums/991-turb...um-silver.html
Best of luck with your new Turbo.
Thanks man, I'm very torn on the color combo. Part of me wants to do rhodium without the red interior, maybe black. I love the classic look of the gt silver/red combo but maybe it's too old fashioned for the new TT? Argh! Btw, grats on the GT3, if I could get an allocation I would have taken one of those instead of the TT. But I've justified in my mind that at least w/ a TT I can drive it in winter IF I want to lol.
http://www.youtube.com/watch?v=L93Kw...iiUCDI:bigbye:
I just ordered mine today. Red w/black interior, red stitching and carbon fiber trim. I was saying in my GT3 defector thread that also ordered PDCC with sport chromo. Hope it has the same effect as in my 991S which handles incredibly.
