Attn Mods/Admins: Missing...
Hey Mods/Admins
Thanks for the new 991 turbo/S forums![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
But maybe only a slight oversight![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
On the left hand navigation menu, 991 turbo/S doesn't appear as a choice under the Turbo forums
But it does only appear on the right hand drop down menu
M/A: Close this thread at your leisure
Cheers
Cheers
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
IIUC, these parts of the forum are built separately. The work to code the left side menu bar is a separate task and apparently no so easily done as the code to add to the forum software (vbulletin) itself. "All in good time" is the usual state of affairs for the left side menu bar. : )
Still plays with cars.
The front page sidebar menu is hard coded and nobody can seem to fix it. I suggest you avoid the problem by using "http:forums.rennlist.com/rennforums"
That way you see ALL the forums, there are quite a fe which aren't on the front page.
Best,
Best,
Newbies Hospitality Director
Hey Mods/Admins
Cheers
Cheers
Once you get used to using a function, it is surprising that the latest Forums can not be accessed in the same way. It would be like Porsche releasing the 991 GT3 and the 991 Turbo with PDK transmission only..... oh wait.... Porsche already did that!
Bad example, never mind!
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
